Type 47 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None ![]() ![]() |
I guess it's been a while since I had a 914 with a set of factory keys.
I thought the black key was a master for everything and the red was just doors and ignition. But when I went to order some blanks, it indicated that was the opposite. |
stoneman30hotmail |
Member ![]() ![]() Group: Members Posts: 80 Joined: 10-September 22 From: Greensboro, NC Member No.: 26,834 Region Association: South East States ![]() |
I have a mess. The car came with two red keys and one metal one, which after this thread I realize in now the main key. But the red and metal ones are cut different. The red ones open the driver door but don't work the ignition. Neither key works the passenger door, front or rear trunks nor glove box. The front hood has half a key stuck in it. I hope to get all these pulled out to mix wafers and match the red ones at least for ignition and both doors.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I have a mess. The car came with two red keys and one metal one, which after this thread I realize in now the main key. But the red and metal ones are cut different. The red ones open the driver door but don't work the ignition. Neither key works the passenger door, front or rear trunks nor glove box. The front hood has half a key stuck in it. I hope to get all these pulled out to mix wafers and match the red ones at least for ignition and both doors. ![]() All three of those keys are the valet key. Your driver's door handle was replaced at some time. Factory door handle replacements come with two red keys. They will not open the front trunk, rear trunk, or glove box, nor the passenger door handle. I agree that you have a mess. But it's easily fixable. |
stoneman30hotmail |
I have a mess. The car came with two red keys and one metal one, which after this thread I realize in now the main key. But the red and metal ones are cut different. The red ones open the driver door but don't work the ignition. Neither key works the passenger door, front or rear trunks nor glove box. The front hood has half a key stuck in it. I hope to get all these pulled out to mix wafers and match the red ones at least for ignition and both doors. ![]() All three of those keys are the valet key. Your driver's door handle was replaced at some time. Factory door handle replacements come with two red keys. They will not open the front trunk, rear trunk, or glove box, nor the passenger door handle. I agree that you have a mess. But it's easily fixable. It may be misleading in the picture, but the metal one only has two cut tracks where the outer one is deeper than the red one which has three tracks which center the ridges where the metal one has the ridges offset all the way to the side. I have it sorted now. I had enough wafers for the door handle and ignition switch. I just put what wafers worked for the hoods and will probably not put the glove lock back in at all. Not completely secure, but good enough. Now I see the ignition switch is cracked. Are they really different by year and not the same as the VW's same years? Jbugs has one for like $9. And otherwise looks like you can pay as much as you want upwards of that. Though probably with shipping AAtlanta may be a fine deal - packed with a new floor. |
Lo-Fi Version | Time is now: 17th June 2024 - 11:28 AM |
