| Olympic 914 |
Jan 27 2023, 08:03 AM
![]() ![]() ![]() Group: Members Posts: 1,770 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
Door latch lube.
The passenger side door latch lock had gotten stiff to operate, to the point where I was worried about breaking off the key. I could still unlock it from the inside latch though. The door latch worked good to open the door, just the lock was stiff. So I took the door apart to work on the latch. The key turned freely in the door handle, so I know the problem wasn’t there. Removed the latch mechanism and scrubbed it in Simple Green in the parts washer, working it to try and get it to move freely. Soaked it overnight in the Simple Green. It still felt a little stiff so I soaked it again overnight in Evapo-Rust. That Really cleaned it up. Washed and dried it with compressed air and lubed with Kroil, working the mechanism to get the lube into it. Then gave it a spray with chain lube. Wiped the excess off and re installed it. It works smoothly, but is still a little stiff, more than the driver’s side. Could this be because the driver’s side lock is used more? And possible worn more? (I will do the drivers side next) The door opens nicely just the lock part is stiff. the key turns freely in the door handle , by itself. I tried it with and without the rod installed first, to make sure there wasn’t any binding there. Before installing the door panel. I did not put any grease on the mechanism because I didn’t want it to harden up in the future and cause problems. Is there a better lube I should have used? @TheCabinetmaker |
| Root_Werks |
Jan 27 2023, 05:02 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,914 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
I use LR2, aviation lube. Probably not the correct stuff to use on locks, but sure works well.
Olympic 914 Door latch lube Jan 27 2023, 08:03 AM
TheCabinetmaker I use a liberal amount of white lithium grease on ... Jan 27 2023, 02:08 PM
vitamin914 I have always liked using the dry teflon spray lub... Jan 27 2023, 03:03 PM
TheCabinetmaker I use it on the interior locks. Don't use grap... Jan 27 2023, 03:16 PM
brant not for the mechanism... but for the lock itself..... Jan 27 2023, 03:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 10:32 AM |
