Deusexmachina77 |
Member ![]() ![]() Group: Members Posts: 93 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest ![]() ![]() |
I have a 76'.
I am in the process of replacing the struts and have decided to replace the tie-rods as well since the joints are trashed. I want to pull the steering gear out so I can work on a bench and not under the car. I studied @IanKarr video https://www.youtube.com/watch?v=MnuYLbZ89y8 but doesn't show it being removed. I can not see a way to remove it without removing a lot of parts of the suspension. In the Hanes manual, you have to remove the auxiliary carrier. (Page 103), Section 10, Removing the auxiliary carrier, Step 5. "Remove the torsion bar adjusting screws then pull off the adjusting levers and seals." I have no clue what this means and could use some instruction. (IMG:style_emoticons/default/confused24.gif) Thank you in advance. Victor |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
They're referring to the torsion bars. (IMG:style_emoticons/default/beerchug.gif)
Deusexmachina77 |
So, Step one: remove the torsion bar. |
Lo-Fi Version | Time is now: 17th June 2024 - 03:38 AM |
