need help removing ball joints, looked at other threads, need some clarification |
914 RZ-1 |
Jan 28 2023, 06:39 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm replacing the ball joints on my car.
1. How does one get the ball joint that is inserted in the control arm off? I've tried raising the whole assembly up with the jack, thinking it was misaligned and tapping it with a hammer to no avail. It's now soaking in penetrating oil. 2. Is there an alternative to the over $100 tool that can be used to get the bottom ball joint nut off? There are posts on this forum that discuss some $45 version on pelican, but all they have is ones costing significantly more. I do NOT want to use a hammer and chisel to get it off if I can help it, and I need to install the new one as well. Here is a view of the nut looking up at it from below. |
914 RZ-1 |
Jan 28 2023, 07:01 PM
bbrock |
Jan 28 2023, 07:07 PM
Is the scissor-like device what is used for question #1? Any tips/tricks for using it? Does the shaft pop off violently? Id the Harbor Freight one good enough for two uses? Thanks! Can't speak to the HF version, but yes, that's the style. Just insert between the ball and control arm and crank and yes, it might pop off violently depending on how much force is needed to pop them loose. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:53 AM |
