Rear trunk latch stuck, how do you get in? |
BR9 |
Jan 28 2023, 12:32 PM
Newbie Group: Members Posts: 24 Joined: 19-February 22 From: FLORIDA Member No.: 26,347 Region Association: South East States |
I can put the key in and it turns to about 1 degree away from where the button should pop out but it stops. I sprayed some PB blaster, and other than making it turn really easily in the zone it could already move in, it didn't help that last little bit to make it open.
I tried slightly pressing on the lid right at the lock but it doesn't help. It's been sitting for 30 years and hasn't been opened in that amount of time. I've owned it since '84 so I know its history. Is there some way to use an o-ring pick or such to get at the mechanism to free it? |
ClayPerrine |
Jan 28 2023, 01:33 PM
Life's been good to me so far..... Group: Admin Posts: 15,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The bitch to this job is you have to look through the hole to line up the socket on the bolts. They are not big bolts, and they are not really torqued tight. But it is hard to get the socket on the. So plan on all day to do it.
r_towle |
Jan 30 2023, 05:14 PM
Custom Member Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
TheCabinetmaker |
Jan 30 2023, 05:18 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
The bitch to this job is you have to look through the hole to line up the socket on the bolts. They are not big bolts, and they are not really torqued tight. But it is hard to get the socket on the. So plan on all day to do it. ^^^^truth I tried this method. It sucked! Took about 20 minutes to say "screw this". Drill the sucker! |
r_towle |
Jan 30 2023, 05:22 PM
The bitch to this job is you have to look through the hole to line up the socket on the bolts. They are not big bolts, and they are not really torqued tight. But it is hard to get the socket on the. So plan on all day to do it. ^^^^truth I tried this method. It sucked! Took about 20 minutes to say "screw this". Drill the sucker! I got it by looking through one hole and socket in the other. Laying on the rear lid….fun times. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:50 AM |
