| apexhound |
Jan 31 2023, 11:15 PM
Newbie ![]() Group: Members Posts: 5 Joined: 28-May 10 From: Los Angeles, California (west-side) Member No.: 11,771 Region Association: Southern California |
Does anyone have a hydraulic clutch kit (or parts) for a 901?
I’ve had enough of breaking/replacing cables (IMG:style_emoticons/default/driving.gif) / (IMG:style_emoticons/default/headbang.gif) , suggestions welcome! Thanks!!!! |
| Superhawk996 |
Feb 1 2023, 12:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,063 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
If you have cables that are repeatedly breaking, you most likely have a bad or missing ground strap between the body and the transmission.
When that ground is missing or too high of resistance, the clutch cable becomes the ground for the starter motor and drawing high current though the steel cable leads to it breaking. |
| apexhound |
Feb 1 2023, 09:50 PM
If you have cables that are repeatedly breaking, you most likely have a bad or missing ground strap between the body and the transmission. When that ground is missing or too high of resistance, the clutch cable becomes the ground for the starter motor and drawing high current though the steel cable leads to it breaking. Thanks Hawk, Great/amazing suggestion - I’ll check the strap. I’ve had a lot of flex in that region of the car, bending exhaust pipes and muffler mounts! I’m running semi-rigid transaxle mounts with a stiffly sprung pressure plate and an aggressive driving style around the cones… the cable takes a lot of tension/cycling - I can imagine if it’s acting as a ground strap too, it’s bound to fail repeatedly! |
apexhound WTB: Hydraulic Clutch Kit/Parts for 901 Jan 31 2023, 11:15 PM
B2524
Does anyone have a hydraulic clutch kit (or parts... Feb 1 2023, 11:35 AM
Dominic I recently picked up a gearbox that had this Hydra... Feb 4 2023, 04:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th September 2026 - 09:17 AM |
