> Parts for 2056, Where to source parts
sjhenry1075
post Dec 8 2022, 09:22 AM
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case.
My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following:
FAT Camshaft FC 442 Camshaft / FC 440 If Smog
71mm Type 4 Crankshaft
2.0 Connecting Rods - Rebuilt
96mm Forged Pistons & Cylinders - Keith Black
WEB Lifters
Front Oil Seal
Rear Main Seal
Gasket Set - German
Engine Hardware Kit - Nuts & Bolts
Main Bearings - Silverline
Rod Bearings - Mahle
HD Double Thrust Cam Bearings (2 Sets of STD)
What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build.
Thoughts?
930cabman
post Dec 9 2022, 08:48 AM
I am no professional engine builder, but have built several over the years. My recent 2056 came in around 8.8. She runs great, nice punch with Weber 44's and an Elgin street cam. My gut tells me anything over 9.0 is potentially asking for trouble (for a street machine) Keep us updated with your build
barringtonpro
post Feb 6 2023, 06:59 AM
QUOTE(930cabman @ Dec 9 2022, 09:48 AM) *
Can I ask which Elgin cam did you use? What rpm did it start to pull from? Also are you using 36mm ventures in the 44 webers or did you choke them down? Thanks
Frank
sjhenry1075   Parts for 2056   Dec 8 2022, 09:22 AM
Montreal914   Parts and machining: European Motorworks in Hawtho...   Dec 8 2022, 10:05 AM
930cabman   All good suggestions, may I add: D Elgin camshaft...   Dec 8 2022, 10:22 AM
914werke   If you local machine shop has the ability to do th...   Dec 8 2022, 11:16 AM
sjhenry1075   If you local machine shop has the ability to do t...   Dec 8 2022, 11:21 AM
sportlicherFahrer   I picked up a nice set of pistons and cylinders an...   Dec 8 2022, 11:28 AM
barefoot   You didn't mention any work needed on the case...   Dec 8 2022, 03:59 PM
mepstein   Billy Ring Performance auto works Kerneysville WV ...   Dec 8 2022, 04:56 PM
BeatNavy   Billy Ring Performance auto works Kerneysville WV...   Dec 8 2022, 07:25 PM
sjhenry1075   Billy Ring Performance auto works Kerneysville W...   Dec 9 2022, 05:57 AM
BeatNavy   There's a ton of people here who can wax more ...   Dec 9 2022, 06:34 AM
sjhenry1075   There's a ton of people here who can wax more...   Dec 9 2022, 08:48 AM
VaccaRabite   Don't you have a 2056? What cam did you use?...   Dec 9 2022, 10:00 AM
sjhenry1075   Don't you have a 2056? What cam did you use...   Dec 9 2022, 10:08 AM
930cabman   I am no professional engine builder, but have buil...   Dec 9 2022, 08:48 AM
barringtonpro   I am no professional engine builder, but have bui...   Feb 6 2023, 06:59 AM
VaccaRabite   I am no professional engine builder, but have bu...   Feb 6 2023, 07:36 AM
DRPHIL914   [quote name='930cabman' post='3044140' date='Dec...   Feb 6 2023, 09:38 AM
VaccaRabite   Zach My motor numbers etc are very close to you...   Feb 8 2023, 09:37 AM
DRPHIL914   Zach My motor numbers etc are very close to yo...   Feb 8 2023, 09:45 AM
BeatNavy   Steve, I have a 2056 with a 9590 sitting on my gar...   Dec 9 2022, 10:50 AM
BeatNavy   I should also add that the 9590, when used with FI...   Dec 9 2022, 11:04 AM
sjhenry1075   I should also add that the 9590, when used with F...   Dec 9 2022, 12:00 PM
JamesJ   Not to pull away from OP's question, but it is...   Dec 9 2022, 12:17 PM
mepstein   Not to pull away from OP's question, but it i...   Dec 9 2022, 12:53 PM
JamesJ   You really have to figure out what made the engin...   Dec 9 2022, 06:46 PM
BeatNavy   If the car was running like a champ, then I wouldn...   Dec 9 2022, 06:58 PM
sjhenry1075   You really have to figure out what made the engi...   Dec 9 2022, 08:54 PM
barnfind9141972   You really have to figure out what made the eng...   Dec 10 2022, 01:09 AM
sjhenry1075   [quote name='sjhenry1075' date='Dec 9...   Dec 10 2022, 09:35 AM
BeatNavy   Yeah, in and of itself, the higher CR wouldn't...   Dec 9 2022, 01:58 PM
JamesJ   @sjhenry1075 Jorge at EM is the one who built my...   Dec 10 2022, 11:06 AM
Montreal914   Jorge at EM is the one who built my engine. I had...   Dec 10 2022, 01:53 PM
JamesJ   Jorge at EM is the one who built my engine. I ha...   Dec 10 2022, 11:21 PM
sjhenry1075   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 10 2022, 07:26 PM
JeffBowlsby   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 10 2022, 11:47 PM
sjhenry1075   [quote name='sjhenry1075' post='3044488' date='De...   Dec 11 2022, 08:17 AM
Geezer914   2056, 9550 cam, Hoffman RS heads, 9:1 CR, 50 mm mo...   Feb 6 2023, 10:35 AM
- Lo-Fi Version Time is now: 17th October 2026 - 02:24 AM
