| DRPHIL914 |
Feb 6 2023, 09:05 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well. to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used. One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors. I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error. I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this. Look forward to some input, thanks!! Phil |
| Superhawk996 |
Feb 7 2023, 03:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,156 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Fair points but let me address throttle by wire.
Drive by wire is but another level of complexity on top of EFI. It was about a decade of the OEMs running conventional cable operated throttles with EFI before they moved to throttle by wire. The safety implications of moving to throttle by wire are staggering. Every prototype I’ve ever tested in has a huge red emergency stop button that kills all power - just in case anything goes haywire with throttle by wire. Throttle by wire may seem like the “easy button” but it is anything but easy. |
| GregAmy |
Feb 7 2023, 04:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,712 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
The safety implications of moving to throttle by wire are staggering. Every prototype I’ve ever tested in has a huge red emergency stop button that kills all power - just in case anything goes haywire with throttle by wire. Ditto. I designed and installed an AEM DBW engine management system on our '08 Civic Si race car (using factory DBW components) and I made sure my kill switch is big and read and easily accessible by the monkey. And while it removes the aggravation of possibly breaking a throttle cable and being stuck (how often does that happen?) it really doesn't offer much advantage*. I would not be comfy doing DBW in my 914. - GA *I suspect, but certainly cannot prove, that the driving force for throttle DBW came from the mid-80s Audi "runaway" issue, and later a Toyota Camry(?), where drivers were insisting that they were smashing on the brakes but the cars kept going. It was ultimately suspected - but not proven - that the drivers were either actually pushing on the throttle instead, or more likely pushing on both, but not on the brakes as hard as they thought they were. DBW fixed that: if you're on the throttle and brake for more than "x" seconds, even lightly, the throttle is brought back to idle. My first experience with that was doing an HPDE in my new '00 Audi S4 while trying to left-foot-brake through the middle of the corner to balance the chassis and keep the turbos spooled; car kept going back to idle. Pissed me off royally... (IMG:style_emoticons/default/biggrin.gif) |
DRPHIL914 Aftermarket FI options for Type 4 motors 2056 or larger Feb 6 2023, 09:05 AM
DRPHIL914 forgot to add this link, its the PMB page listing ... Feb 6 2023, 09:06 AM
GregAmy We have several good discussion topics already goi... Feb 6 2023, 09:30 AM
DRPHIL914
We have several good discussion topics already go... Feb 6 2023, 09:45 AM
scott_in_nh
We have several good discussion topics already go... Feb 8 2023, 04:37 PM
GregAmy That was a good read - thanks for taking the time ... Feb 8 2023, 04:57 PM
scott_in_nh
That was a good read - thanks for taking the time... Feb 8 2023, 05:25 PM
GregAmy Well, thinking outside the box, there's no rea... Feb 6 2023, 09:53 AM
Geezer914 2056, 9:1 CR. 9550 cam, 50mm vanagon throttle bod... Feb 6 2023, 10:10 AM
rgolia I am looking hard at this as I am getting tired of... Feb 6 2023, 01:48 PM
mihai914
I am looking hard at this as I am getting tired o... Feb 7 2023, 08:04 AM
914Sixer Currently sold out but more on the way. Feb 6 2023, 02:05 PM
DRPHIL914 ok wow lots of great comments here i just got caug... Feb 7 2023, 10:57 AM
Superhawk996
seems keeping direct injection is best
Totally... Feb 7 2023, 12:30 PM
GregAmy You can do that. I just decided to use the stock r... Feb 6 2023, 04:11 PM
billh1963 Probably a stupid question but are Holley sniper a... Feb 6 2023, 04:18 PM
GregAmy
Probably a stupid question but are Holley sniper ... Feb 6 2023, 04:35 PM
mihai914
Probably a stupid question but are Holley sniper ... Feb 7 2023, 07:46 AM
Superhawk996
Probably a stupid question but are Holley sniper... Feb 7 2023, 08:58 AM
914werke Ive talked to those guys, it seems the real value ... Feb 6 2023, 06:35 PM
JamesM
Phi... Feb 6 2023, 07:19 PM
MSGGrunt I have converted my 1969 TR6 with twin SU side dra... Feb 6 2023, 07:24 PM
emerygt350 If it were me, I would see if the stock FI will wo... Feb 7 2023, 08:33 AM
emerygt350 I work with early tbi (CFI in the ford world). It... Feb 7 2023, 10:35 AM
Superhawk996
I work with early tbi (CFI in the ford world). I... Feb 7 2023, 12:22 PM
Jack Standz
I work with early tbi (CFI in the ford world). I... Feb 7 2023, 01:03 PM
Aerostatwv I thought there is a difference with injectors. Th... Feb 7 2023, 11:02 AM
Superhawk996
I thought there is a difference with injectors. T... Feb 7 2023, 12:36 PM
Superhawk996 What is with with the love of TBI?
Sure dual TBI... Feb 7 2023, 01:32 PM
mihai914
Sure dual TB... Feb 7 2023, 02:46 PM
JamesM
Sniper EFI, FiTEch and all other similar product... Feb 7 2023, 03:19 PM
Superhawk996
Using the term "Self Tune" is along the... Feb 7 2023, 03:38 PM
mihai914
[quote name='JamesM' post='3056265' date='Feb 7 2... Feb 7 2023, 04:04 PM
emerygt350
Sure dual T... Feb 7 2023, 03:46 PM
Jack Standz
Sure dual TB... Feb 7 2023, 03:38 PM
rhodyguy A local member had a big T4 and I think he used th... Feb 7 2023, 01:43 PM
rbzymek I worked at Ford in the engine controls department... Feb 7 2023, 02:01 PM
Superhawk996 :beer3: The initial Audi unintended acceleration ... Feb 7 2023, 04:38 PM
Superhawk996 The Toyota unintended acceleration issue was a res... Feb 7 2023, 04:41 PM
mihai914 Food for thought:
https://www.holley.com/blog/pos... Feb 7 2023, 05:11 PM
Superhawk996
Food for thought:
https://www.holley.com/blog/po... Feb 7 2023, 05:21 PM
Jack Standz Well, I don't know how Edelbrock got it to wor... Feb 7 2023, 06:45 PM
Superhawk996
Well, I don't know how Edelbrock got it to wo... Feb 7 2023, 07:29 PM
emerygt350 No fun car of mine is in spec. And they both have... Feb 7 2023, 07:30 PM
Superhawk996 Was reading the Holly quick start guide. This gui... Feb 7 2023, 07:53 PM
bkrantz I have the Dub Shop kit on my 2056. As delivered ... Feb 7 2023, 09:12 PM
DRPHIL914
I have the Dub Shop kit on my 2056. As delivered... Feb 8 2023, 07:51 AM
rgolia
I have the Dub Shop kit on my 2056. As delivere... Feb 8 2023, 11:52 AM
DRPHIL914
[quote name='bkrantz' post='3056369' date='Feb 7... Feb 8 2023, 12:57 PM
DRPHIL914
mihai914
I have the Dub Shop kit on my 2056. As delivere... Feb 8 2023, 01:20 PM
DRPHIL914
[quote name='DRPHIL914' post='3056437' date='Feb ... Feb 8 2023, 01:36 PM
rgolia
I have the Dub Shop kit on my 2056. As delivered... Feb 8 2023, 11:53 AM
bkrantz
I have the Dub Shop kit on my 2056. As delivere... Feb 8 2023, 09:09 PM
rgolia
[quote name='bkrantz' post='3056369' date='Feb 7... Feb 9 2023, 08:40 AM
bkrantz
[quote name='bkrantz' post='3056613' date='Feb 8 ... Feb 9 2023, 09:03 PM
bkrantz
[quote name='bkrantz' post='3056613' date='Feb 8 ... Mar 24 2023, 08:54 PM
emerygt350 superhawk, that is awesome. However, I have had a... Feb 8 2023, 07:24 AM
GeorgeKopf Has anybody looked at Simple Digital Systems for a... Feb 8 2023, 02:45 PM
mihai914 Ok, to keep the ball rolling, can we also talk abo... Feb 8 2023, 07:33 PM
mepstein Installing FI is never cheap. People always undere... Feb 8 2023, 08:28 PM
r_towle Last time I looked at this CBPerformance sold comp... Feb 8 2023, 10:54 PM
Superhawk996 :agree:
Like rgolia, I’ve leaned toward DubSho... Feb 9 2023, 08:48 AM
mihai914 I found this thread specifically about the Dub Sho... Feb 9 2023, 10:45 AM
GregAmy Just a quick bump to report a new "find... Mar 24 2023, 01:57 PM
jd74914 That’s wild. Had to have been done in the late 9... Mar 24 2023, 07:55 PM
GregAmy
That’s wild. Had to have been done in the late ... Mar 24 2023, 08:55 PM
jd74914 :agree: That stuff really was ahead of it’s time... Mar 25 2023, 05:04 AM
GregAmy
That’s before my time-I would have been in elem... Mar 25 2023, 05:44 AM
r_towle Back about 15,years ago, I tuned a 2.4 liter to 15... Mar 25 2023, 09:16 AM
targa72e Not quite 914 FI related but Porsche related. I re... Mar 25 2023, 10:24 PM
VaccaRabite One of the things I'd be wary of with the Dub ... Mar 27 2023, 06:23 AM
GregAmy
One of the things I'd be wary of with the Dub... Mar 27 2023, 11:19 AM
GregAmy
[quote name='VaccaRabite' post='3067937' date='Ma... Mar 27 2023, 05:28 PM
rick 918-S
[quote name='VaccaRabite' post='3067937' date='M... Mar 28 2023, 01:14 AM
r_towle
[quote name='GregAmy' post='3068081' date='Mar 27... Apr 9 2024, 02:43 PM
VaccaRabite
[quote name='VaccaRabite' post='3067937' date='M... Mar 28 2023, 05:23 AM
GregAmy
Interesting. I'm assuming the timing retard ... Mar 28 2023, 05:41 AM
Geezer914 Search for a used Ljet system. You can adjust the... Mar 27 2023, 09:31 AM
ClayPerrine
Search for a used Ljet system. You can adjust th... Mar 27 2023, 10:57 AM
falcor75
Search for a used Ljet system. You can adjust t... Mar 27 2023, 12:30 PM
jd74914 Controlling idle with spark timing is really the w... Mar 27 2023, 11:52 PM
jd74914 In tank is the way to go if you can make it work. ... Mar 28 2023, 01:31 AM
ClayPerrine
In tank is the way to go if you can make it work.... Mar 28 2023, 05:04 AM
Gatornapper Impecable timing as to this thread - almost as if ... Apr 8 2024, 06:55 PM
DRPHIL914
Impecable timing as to this thread - almost as if... Apr 9 2024, 10:40 AM
DRPHIL914 @[url=http://www.914world.com/bbs2/index.php?showu... Apr 9 2024, 10:41 AM
VaccaRabite
@[url=http://www.914world.com/bbs2/index.php?show... Apr 9 2024, 07:13 PM
mepstein There are places to send a throttle body out, get ... Apr 9 2024, 04:35 PM
flxzcat
There are places to send a throttle body out, get... Nov 6 2024, 04:18 PM
Gatornapper Thanks Ben - did not know that.
The 50mm (from 45... Apr 9 2024, 07:29 PM
flxzcat Regarding previous talk of Weber like FI throttle ... Nov 6 2024, 04:32 PM
914werke RE: Aftermarket FI options for Type 4 motors 2056 or larger Nov 6 2024, 05:55 PM
Craigers17 I watched this video from Jake Raby over the weeke... Nov 7 2024, 03:55 PM
JamesM
I watched this video from Jake Raby over the week... Nov 8 2024, 01:44 AM
914werke It seems that he and Mario from the Dub Shop hav... Nov 7 2024, 06:16 PM
Craigers17
It seems that he and Mario from the Dub Shop ha... Nov 7 2024, 08:28 PM
Mikey914 Well, I'm currently working on a version of a ... Nov 10 2024, 03:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 04:38 PM |
