> 16 X 7 Fuchs clone wheel fitment question
technicalninja
post Feb 7 2023, 10:14 PM
New member here...
I'm piss poor at the search function on this site and was trying to find fitment info on this set up.
https://fuchswheelcompany.ca/product/16x7-f...eel-for-porshe/
They list it a 16X7 with an offset of 23.3.
From what I have found so far, they look like they might require 12 mm spacers to work on a stock 75 914 narrow body.
This car will be at or near stock ride height and a weekend play toy. It currently has no sway bars but that will probably change...
I'm planning on using PBR's 5 lug 914-4 front rotors, the Uro 914 5 lug rear flange with turned down PBR 914-6 rear rotors, and stock calipers.
I'd like to use this tire. (205/60r16)
https://www.tirerack.com/tires/TireSearchRe...performance=ALL
I'm new to the 914 and can't figure offsets properly yet on this chassis
I would appreciate thoughts, tips and any suggestions.
Do I have a chance?
mmascari
post Feb 7 2023, 11:50 PM
I just installed Maxilite wheels on my narrow body car. I originally purchased 16x7 wheels to test fit. The 16x7 did not fit in the back, although I have Boxster brakes, so needed a spacer that pushed the wheel away from the large caliper. I ended up purchasing 16x6 Maxilites for all 4 corners. I am running 205/55/16 tires which is the correct size.
technicalninja   16 X 7 Fuchs clone wheel fitment question   Feb 7 2023, 10:14 PM
tygaboy   7s are a "maybe" on the rear of a narrow...   Feb 7 2023, 11:00 PM
mmascari   I just installed Maxilite wheels on my narrow body...   Feb 7 2023, 11:50 PM
CCE   I just installed Maxilite wheels on my narrow bod...   Feb 8 2023, 09:05 AM
technicalninja   I just installed Maxilite wheels on my narrow bod...   Feb 8 2023, 01:10 AM
mmascari   I just installed Maxilite wheels on my narrow bo...   Feb 8 2023, 10:02 PM
drem914   I don't recall where the 16x7 wheels came fr...   Feb 9 2023, 02:36 PM
emerygt350   I love the look of those wheels. Of course, there...   Feb 8 2023, 07:16 AM
dr914@autoatlanta.com   7x16 will fit stock fender wells with the correct ...   Feb 8 2023, 10:30 AM
mgarrison   Here's the Fuchs wheel offset chart I used to ...   Feb 8 2023, 12:27 PM
Root_Werks   16x7's may fit as some have said. Depending o...   Feb 8 2023, 01:06 PM
technicalninja   Here's the Fuchs wheel offset chart I used to...   Feb 8 2023, 05:13 PM
sixnotfour   17x7s ,,offsett is the important thing.... 7 INCH ...   Feb 8 2023, 08:12 PM
Root_Werks   Also believe if you can locate 16x7 951 fuchs, it ...   Feb 9 2023, 01:33 PM
sixnotfour   Also believe if you can locate 16x7 951 fuchs, it...   Feb 9 2023, 04:57 PM
mepstein   Also believe if you can locate 16x7 951 fuchs, i...   Feb 9 2023, 05:25 PM
technicalninja   Thanks you all for the advice. I am going with 16...   Feb 9 2023, 03:46 PM
76-914   Lots of great info here and timely, at that, as I ...   Feb 9 2023, 05:06 PM
technicalninja   I e-mailed DR911 and got a responce. Their wheels...   Feb 9 2023, 08:30 PM
mihai914   I e-mailed DR911 and got a responce. Their wheel...   Feb 10 2023, 11:45 AM
bajafreaks   I e-mailed DR911 and got a responce. Their wheel...   Dec 22 2024, 12:15 PM
dr914@autoatlanta.com   23.3 will NOT work on 914 stock rear quarters but...   Feb 10 2023, 12:12 PM
technicalninja   Sorry, the guy is a scam artist. https://rennl...   Mar 11 2023, 08:59 PM
technicalninja   Finally received the lug nuts... They look ok like...   Mar 19 2023, 11:22 AM
technicalninja   His website looks screwed up. When I bought the b...   Dec 22 2024, 12:26 PM
bajafreaks   His website looks screwed up. When I bought the ...   Dec 22 2024, 01:29 PM
technicalninja   After I purchased those wheels Mepstein posted som...   Dec 22 2024, 12:52 PM
cgnj   Road Roach with Boxster Wheels 16x6 front 16x7 rea...   Dec 22 2024, 01:10 PM
technicalninja   Back then there were multiple places to buy the cl...   Dec 22 2024, 01:54 PM
sixnotfour   I've just welded an inch to the inners ,,911R ...   Dec 24 2024, 12:19 PM
- Lo-Fi Version Time is now: 13th November 2026 - 10:30 PM
