> 16 X 7 Fuchs clone wheel fitment question
technicalninja
post Feb 7 2023, 10:14 PM
New member here...
I'm piss poor at the search function on this site and was trying to find fitment info on this set up.
https://fuchswheelcompany.ca/product/16x7-f...eel-for-porshe/
They list it a 16X7 with an offset of 23.3.
From what I have found so far, they look like they might require 12 mm spacers to work on a stock 75 914 narrow body.
This car will be at or near stock ride height and a weekend play toy. It currently has no sway bars but that will probably change...
I'm planning on using PBR's 5 lug 914-4 front rotors, the Uro 914 5 lug rear flange with turned down PBR 914-6 rear rotors, and stock calipers.
I'd like to use this tire. (205/60r16)
https://www.tirerack.com/tires/TireSearchRe...performance=ALL
I'm new to the 914 and can't figure offsets properly yet on this chassis
I would appreciate thoughts, tips and any suggestions.
Do I have a chance?
technicalninja
post Feb 8 2023, 01:10 AM
QUOTE(mmascari @ Feb 7 2023, 11:50 PM) *
I just installed Maxilite wheels on my narrow body car. I originally purchased 16x7 wheels to test fit. The 16x7 did not fit in the back, although I have Boxster brakes, so needed a spacer that pushed the wheel away from the large caliper. I ended up purchasing 16x6 Maxilites for all 4 corners. I am running 205/55/16 tires which is the correct size.
I like that size better...
I can get Continental DWS in that size!
My favorite DD all season tire.
Did the interference with the spacer installed look less than the width of the spacer?
What were the offsets you tried?
Maxlight shows 23.3 for the seven and 36 for the six.
Were you able to return the 16X7s to the seller?
If so, who did you purchase them from.
And final question! Is that your E36 M3 sitting across the road?
My P-wagon is silver just like yours but my 98 M3 is alpine white.
Purple ones are sort of rare...
Thanks, that's the type of assistance I was looking for!
Tygaboy, thank you as well. On most cars I have no compunctions about a fender roll but, this car I found is a "museum piece" quality chassis. I'm going to be damn careful not to drill holes, cut into what appears to be a flawless wiring harness, or roll the apparently perfect fenders.
All mods will be "bolt on" and the original pieces that I remove will be restored and stored for a future owner.
This car was "advertised" as 31,000 miles and I'm starting to believe it.
I may take the easy way out and just order mmascari has.
Thanks guys...
technicalninja   16 X 7 Fuchs clone wheel fitment question   Feb 7 2023, 10:14 PM
tygaboy   7s are a "maybe" on the rear of a narrow...   Feb 7 2023, 11:00 PM
mmascari   I just installed Maxilite wheels on my narrow body...   Feb 7 2023, 11:50 PM
CCE   I just installed Maxilite wheels on my narrow bod...   Feb 8 2023, 09:05 AM
technicalninja   I just installed Maxilite wheels on my narrow bod...   Feb 8 2023, 01:10 AM
mmascari   I just installed Maxilite wheels on my narrow bo...   Feb 8 2023, 10:02 PM
drem914   I don't recall where the 16x7 wheels came fr...   Feb 9 2023, 02:36 PM
emerygt350   I love the look of those wheels. Of course, there...   Feb 8 2023, 07:16 AM
dr914@autoatlanta.com   7x16 will fit stock fender wells with the correct ...   Feb 8 2023, 10:30 AM
mgarrison   Here's the Fuchs wheel offset chart I used to ...   Feb 8 2023, 12:27 PM
Root_Werks   16x7's may fit as some have said. Depending o...   Feb 8 2023, 01:06 PM
technicalninja   Here's the Fuchs wheel offset chart I used to...   Feb 8 2023, 05:13 PM
sixnotfour   17x7s ,,offsett is the important thing.... 7 INCH ...   Feb 8 2023, 08:12 PM
Root_Werks   Also believe if you can locate 16x7 951 fuchs, it ...   Feb 9 2023, 01:33 PM
sixnotfour   Also believe if you can locate 16x7 951 fuchs, it...   Feb 9 2023, 04:57 PM
mepstein   Also believe if you can locate 16x7 951 fuchs, i...   Feb 9 2023, 05:25 PM
technicalninja   Thanks you all for the advice. I am going with 16...   Feb 9 2023, 03:46 PM
76-914   Lots of great info here and timely, at that, as I ...   Feb 9 2023, 05:06 PM
technicalninja   I e-mailed DR911 and got a responce. Their wheels...   Feb 9 2023, 08:30 PM
mihai914   I e-mailed DR911 and got a responce. Their wheel...   Feb 10 2023, 11:45 AM
bajafreaks   I e-mailed DR911 and got a responce. Their wheel...   Dec 22 2024, 12:15 PM
dr914@autoatlanta.com   23.3 will NOT work on 914 stock rear quarters but...   Feb 10 2023, 12:12 PM
technicalninja   Sorry, the guy is a scam artist. https://rennl...   Mar 11 2023, 08:59 PM
technicalninja   Finally received the lug nuts... They look ok like...   Mar 19 2023, 11:22 AM
technicalninja   His website looks screwed up. When I bought the b...   Dec 22 2024, 12:26 PM
bajafreaks   His website looks screwed up. When I bought the ...   Dec 22 2024, 01:29 PM
technicalninja   After I purchased those wheels Mepstein posted som...   Dec 22 2024, 12:52 PM
cgnj   Road Roach with Boxster Wheels 16x6 front 16x7 rea...   Dec 22 2024, 01:10 PM
technicalninja   Back then there were multiple places to buy the cl...   Dec 22 2024, 01:54 PM
sixnotfour   I've just welded an inch to the inners ,,911R ...   Dec 24 2024, 12:19 PM
- Lo-Fi Version Time is now: 13th November 2026 - 10:30 PM
