| FJ1200 |
May 30 2020, 08:28 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
| Morrie |
Feb 8 2023, 08:14 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region
Rather than create a new thread, I am going to jump on an oil leak thread that is already out there that is in the same vein.
I've pulled the drivetrain to do some leak repair. I know I need to do pushrod tube seals and valve cover gaskets. I assumed I had oil galley plugs leaking and possibly oil cooler, so I pulled the shroud. I have not cleaned the case, so the oil you see there is as it was when I pulled the fan housing. I see greasy engine but not the heavy dripping I see on the ground. I do see oil dripping off the filter bottom in the car and now seeing the top I see oil pooled on top of the filter stand. I do not see indications of oil coming from the cooler or cooler seals, the oil pressure sender, the oil filler box, etc.... (yes, the copious amounts of sealant used is cringe worthy and not my doing) I have thoughts of stuck oil pressure relief valve, crack, warp, or defect in the filter stand, or filters that just don't seal. Has anyone seen this and root caused it? |
FJ1200 Oil leak repair May 30 2020, 08:28 AM
Superhawk996 :wttc:
Wecome to 914's.
Two rules of 914... May 30 2020, 08:43 AM
FJ1200 Thanks, for the response.
I know, there has to be... May 30 2020, 08:55 AM
Superhawk996
I know, there has to b... May 30 2020, 09:11 AM
FJ1200 Just checked the oil pressure switch, dry. As a ma... May 30 2020, 09:31 AM
Superhawk996
With Porsche parts prices what they are this will... May 30 2020, 09:44 AM
FJ1200 Thanks,
I have not done a 901, but I have done Au... May 30 2020, 09:54 AM
Superhawk996
Thanks,
I have not done a 901, but I have done A... May 30 2020, 10:05 AM
North Coast Jim Buy the Harbor Freight hydraulic lift table. The 8... May 30 2020, 10:07 AM
Bleyseng :ttiwwp: May 30 2020, 10:19 AM
FJ1200 Thanks for the input guys, money is a little tight... May 30 2020, 10:19 AM
FJ1200 All right, I am going to attempt to post a picture... May 30 2020, 12:12 PM
ndfrigi
All right, I am going to attempt to post a pictur... May 30 2020, 01:08 PM
FJ1200 Well, I bit the bullet and dropped the engine/tran... May 31 2020, 06:06 AM
Superhawk996 :cheer:
:trophy: May 31 2020, 07:47 AM
FJ1200 Miracle of all miracles, all of the oil stays in t... Jun 2 2020, 05:33 PM
Dave_Darling There's at least a decent chance that much of ... Feb 8 2023, 09:00 PM
Superhawk996
Hopefully that's not a crack I see where the... Feb 9 2023, 09:10 AM
Morrie
Hopefully that's not a crack I see where th... Feb 9 2023, 02:12 PM
Geezer914 Nice! Love the color. With a 914 that's ... Feb 9 2023, 06:55 AM
Superhawk996 Someone else just went through a similar leak with... Feb 9 2023, 09:06 AM
Morrie
Someone else just went through a similar leak wit... Feb 9 2023, 02:19 PM
bkrantz
Someone else just went through a similar leak wi... Feb 9 2023, 08:33 PM
Superhawk996
That was me.
I didn’t want to rat on you ... Feb 9 2023, 09:00 PM
bkrantz
That was me.
I didn’t want to rat on you ... Feb 10 2023, 08:28 PM
Superhawk996 Oil pressure relief valve has no bearing on the oi... Feb 9 2023, 02:33 PM
Morrie
Oil pressure relief valve has no bearing on the o... Feb 9 2023, 07:58 PM
930cabman I was chasing an oil leak at the front end and fou... Feb 10 2023, 07:21 PM
Superhawk996
I was chasing an oil leak at the front end and fo... Feb 10 2023, 08:24 PM
930cabman
[quote name='930cabman' post='3057145' date='Feb ... Feb 11 2023, 07:56 AM
Superhawk996
[quote name='930cabman' post='3057145' date='Feb... Feb 11 2023, 08:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 12:33 AM |
