| FJ1200 |
May 30 2020, 08:28 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Greetings,
Fairly new to the forums and owner of a 1972 teener. I bought the car last spring with a slightly hot rodded 2.0 and a side shift conversion. The true upside is ZERO rust, I have a lift and have inspected every inch of the car. The issue I have is that the oil filter flange is leaking badly (1qt/20 miles). Upon inspection it appears that the upper nut can not be removed without removing the oil cooler. I have new oil cooler seals and the oil filter flange gasket coming from Auto Atlanta. Question is, has anyone ever removed the filter flange in the car? I really would rather not perform an engine drop this week, but I will if needed. Just a little background, until 5 yrs ago I was an Audi dealer shop foreman for 25 years. As a result the nuts and bolts don't bother me at all. It is more current time constraints and the want to drive the car. Thanks, Daniel |
| Superhawk996 |
Feb 9 2023, 09:06 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,177 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Someone else just went through a similar leak with puddling on top of the oil filter.
Problem was oil filter was not properly tightened. Simple mistake. Same thing going on here? |
| Morrie |
Feb 9 2023, 02:19 PM
Member ![]() ![]() Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region
Someone else just went through a similar leak with puddling on top of the oil filter. Problem was oil filter was not properly tightened. Simple mistake. Same thing going on here? That was my first thought (hope) but the filter is snug and this has been leaking over the course of several oil filter changes. I do have a couple spare filter stands. I am going to look very closely for defects on the sealing bead on the casting where it meets the filter, just to be sure. You don't think that a stuck oil pressure relief valve pushing oil past the filter seal could be at fault? I hate to pull them if there is little to no chance but if someone thinks it is possible I will. Would you pull all those threaded galley plugs and reseal them? If so, what sealant would you use? Sorry for all the dumb questions. Try not to be too hard on me. I've rebuilt 616 engines with no leaks so I know it is possible, but the galley plugs we use on those are press in replacements. |
| bkrantz |
Feb 9 2023, 08:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,816 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Someone else just went through a similar leak with puddling on top of the oil filter. Problem was oil filter was not properly tightened. Simple mistake. Same thing going on here? That was my first thought (hope) but the filter is snug and this has been leaking over the course of several oil filter changes. I do have a couple spare filter stands. I am going to look very closely for defects on the sealing bead on the casting where it meets the filter, just to be sure. You don't think that a stuck oil pressure relief valve pushing oil past the filter seal could be at fault? I hate to pull them if there is little to no chance but if someone thinks it is possible I will. Would you pull all those threaded galley plugs and reseal them? If so, what sealant would you use? Sorry for all the dumb questions. Try not to be too hard on me. I've rebuilt 616 engines with no leaks so I know it is possible, but the galley plugs we use on those are press in replacements. That was me. I HOPE most of the oil that leaked on mine came out of the filter, but I have changed some other things, too. I would not pull the galley plugs unless you have some evidence that one is leaking. I sympathize with your struggle. (IMG:style_emoticons/default/headbang.gif) |
FJ1200 Oil leak repair May 30 2020, 08:28 AM
Superhawk996 :wttc:
Wecome to 914's.
Two rules of 914... May 30 2020, 08:43 AM
FJ1200 Thanks, for the response.
I know, there has to be... May 30 2020, 08:55 AM
Superhawk996
I know, there has to b... May 30 2020, 09:11 AM
FJ1200 Just checked the oil pressure switch, dry. As a ma... May 30 2020, 09:31 AM
Superhawk996
With Porsche parts prices what they are this will... May 30 2020, 09:44 AM
FJ1200 Thanks,
I have not done a 901, but I have done Au... May 30 2020, 09:54 AM
Superhawk996
Thanks,
I have not done a 901, but I have done A... May 30 2020, 10:05 AM
North Coast Jim Buy the Harbor Freight hydraulic lift table. The 8... May 30 2020, 10:07 AM
Bleyseng :ttiwwp: May 30 2020, 10:19 AM
FJ1200 Thanks for the input guys, money is a little tight... May 30 2020, 10:19 AM
FJ1200 All right, I am going to attempt to post a picture... May 30 2020, 12:12 PM
ndfrigi
All right, I am going to attempt to post a pictur... May 30 2020, 01:08 PM
FJ1200 Well, I bit the bullet and dropped the engine/tran... May 31 2020, 06:06 AM
Superhawk996 :cheer:
:trophy: May 31 2020, 07:47 AM
FJ1200 Miracle of all miracles, all of the oil stays in t... Jun 2 2020, 05:33 PM
Morrie Rather than create a new thread, I am going to jum... Feb 8 2023, 08:14 PM
Dave_Darling There's at least a decent chance that much of ... Feb 8 2023, 09:00 PM
Superhawk996
Hopefully that's not a crack I see where the... Feb 9 2023, 09:10 AM
Morrie
Hopefully that's not a crack I see where th... Feb 9 2023, 02:12 PM
Geezer914 Nice! Love the color. With a 914 that's ... Feb 9 2023, 06:55 AM
Superhawk996
That was me.
I didn’t want to rat on you ... Feb 9 2023, 09:00 PM
bkrantz
That was me.
I didn’t want to rat on you ... Feb 10 2023, 08:28 PM
Superhawk996 Oil pressure relief valve has no bearing on the oi... Feb 9 2023, 02:33 PM
Morrie
Oil pressure relief valve has no bearing on the o... Feb 9 2023, 07:58 PM
930cabman I was chasing an oil leak at the front end and fou... Feb 10 2023, 07:21 PM
Superhawk996
I was chasing an oil leak at the front end and fo... Feb 10 2023, 08:24 PM
930cabman
[quote name='930cabman' post='3057145' date='Feb ... Feb 11 2023, 07:56 AM
Superhawk996
[quote name='930cabman' post='3057145' date='Feb... Feb 11 2023, 08:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 12:33 AM |
