| technicalninja |
Feb 15 2023, 09:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Does anyone have a modern compressor installed in a 914?
If so, I'd love more information on this. I run a shop that specializes in automotive AC systems and my play-toys all have killer ac. https://granburyautoac.com/ I'm planning a 134 conversion that uses a condenser behind the bumper and I need a modern compressor to make this work. The bumper has to be either a fiberglass replacement or something else (space reasons). I'll be using a modified 916 front cap. The square York style needs to "leave the building"... Any suggestions? |
| technicalninja |
Feb 15 2023, 01:33 PM
I go new OEM (commonly Denso) and donate all of my cores to Yellow Rose so they have lots of compressors to snag internals out of.
It is usually cheaper to replace a whole compressor nowadays than to install a clutch so a bunch (50%) of my cores are perfectly good. Makes for good relations with your rebuilder when you bring them 2-300 lbs. of decent cores. Yes, I know cheap Chinese clutches are available. I've had too many problems with Chinese stuff to put them on a customer car. Mine own stuff is a different matter... |
technicalninja Aftermarket AC compressors Feb 15 2023, 09:19 AM
ClayPerrine
Does anyone have a modern compressor installed in... Feb 15 2023, 09:45 AM
JamesJ
Does anyone have a modern compressor installed i... Feb 16 2023, 02:31 PM
Jim C Does anyone know of a source for rebuilt York boat... Feb 15 2023, 01:10 PM
technicalninja Yep. I use Yellow Rose rebuilders when I cannot bu... Feb 15 2023, 01:27 PM
Jim C
Yep. I use Yellow Rose rebuilders when I cannot b... Nov 16 2023, 07:36 AM
technicalninja
Ice Auto Air makes a compressor kit for the Type... Feb 15 2023, 01:51 PM
ClayPerrine
Ice Auto Air makes a compressor kit for the Typ... Feb 15 2023, 02:50 PM
technicalninja OH, thank you soooo much!
Yes, I do want to s... Feb 15 2023, 10:47 PM
Jeff_72 Im a newbie here, but this is my new favorite grou... Feb 16 2023, 10:19 AM
ClayPerrine Y'all need to come to Mayo Performance in Eule... Feb 16 2023, 11:06 AM
technicalninja My dad knew Zim and Mayo when they worked for Gree... Feb 16 2023, 11:39 AM
JamesJ
Does anyone have a modern compressor installed i... Feb 16 2023, 02:35 PM
ClayPerrine
[quote name='ClayPerrine' post='3058259' date='Fe... Feb 16 2023, 04:11 PM
AZBanks Still a work in progress. Buying a new house that ... Feb 16 2023, 05:39 PM
burton73 Mark Sonners and I are trying to figure out an ele... Nov 10 2023, 03:43 PM
Chris914n6 Wonder how I missed this thread. :sleep:
Sande... Nov 10 2023, 05:53 PM
technicalninja Bob, whatever you do make sure the compressor is a... Nov 10 2023, 08:52 PM
Chris914n6
The fans are only needed below 20 mph.
If the fan... Nov 10 2023, 10:44 PM
technicalninja
If the fa... Nov 11 2023, 12:38 AM
Morrie
My favorite complaint is "turn this bitch do... Nov 15 2023, 09:02 PM
friethmiller
My favorite complaint is "turn this bitch d... Nov 16 2023, 02:46 PM
technicalninja No I haven't yet.
I'm a one-man shop (wif... Nov 16 2023, 09:14 AM
friethmiller Here's a pic of my compressor set-up prior to ... Nov 16 2023, 02:54 PM
technicalninja
Here's a pic of my compressor set-up prior to... Nov 16 2023, 03:13 PM
friethmiller
Here's a pic of my compressor set-up prior t... Nov 16 2023, 03:48 PM
ClayPerrine
I plan on buying a new compressor and implementi... Nov 16 2023, 04:28 PM
technicalninja I'm reading that he has two cars...
I would a... Nov 16 2023, 04:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:41 PM |
