| tshih914 |
Feb 12 2023, 06:00 AM
Member ![]() ![]() Group: Members Posts: 79 Joined: 17-July 05 From: central NJ Member No.: 4,426 |
I am starting to reassemble my 1975 2L engine after tearing it apart 20 years ago. As it has been a long while since I started the teardown, I don't remember where and what all the pieces are. It would be awesome if anyone would send/post me a photo showing all the pieces and where they go (of the complete engine tins). Even better if anyone could tell me if a source of aftermarket engine tins can be found.
Thanks in advance, Tom |
| 914werke |
Feb 12 2023, 12:09 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,475 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
No source for new. Best is to figure out what you have & fill in the missing.
Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) ![]() |
| VaccaRabite |
Feb 13 2023, 09:06 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,817 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) ![]() When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach |
| tshih914 |
Feb 15 2023, 05:58 PM
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) ![]() When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. |
| tshih914 |
Feb 15 2023, 06:34 PM
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) ![]() When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. Found a box containing piece #1 and 27 in addition to the alternator and piece of the fuel rail. Attached thumbnail(s) |
| TJB/914 |
Feb 15 2023, 06:41 PM
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) ![]() When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. Found a box containing piece #1 and 27 in addition to the alternator and piece of the fuel rail. tshih914 I think I have some of the lower tin pieces that's off a 1974 1.8 motor. Question from the experts? Is i.8 tin the same as 2.0?? Tom |
tshih914 New Engine tin source? Feb 12 2023, 06:00 AM
JeffBowlsby New Carbon fiber tin is available but it’s ... Feb 12 2023, 07:14 AM
r_towle
New Carbon fiber tin is available but it’s ... Feb 12 2023, 04:43 PM
Superhawk996
[quote name='JeffBowlsby' post='3057494' date='Fe... Feb 12 2023, 04:52 PM
brant Buy a Haynes manual Feb 12 2023, 07:46 AM
zoomCat Check page 197:
http://p914-6info.net/PDFs/Group%... Feb 12 2023, 09:57 AM
ClayPerrine
I think I have some of the lower tin pieces that... Feb 16 2023, 02:05 PM
TJB/914
I think I have some of the lower tin pieces tha... Feb 17 2023, 06:57 AM
tshih914
[quote name='ClayPerrine' post='3058552' date='Fe... Mar 4 2023, 01:03 PM
tshih914
[quote name='tshih914' post='3058345' date='Feb 1... Feb 15 2023, 06:47 PM
930cabman There is plenty of old stuff floating around, migh... Feb 12 2023, 03:09 PM
tshih914
There is plenty of old stuff floating around, mig... Feb 15 2023, 05:55 PM
914werke For that princely sum you'd thinks they were c... Feb 12 2023, 05:01 PM
cgnj
For that princely sum you'd thinks they were ... Feb 12 2023, 10:13 PM
r_towle I can’t imagine brand new steel would be cheaper Feb 12 2023, 06:02 PM
bkrantz And think of the enormous weight savings! Feb 12 2023, 08:21 PM
CCE If money is not an issue.make it carbon fiber…
... Feb 13 2023, 08:48 AM
Krieger That is your air injection system. The one way val... Feb 15 2023, 07:03 PM
tshih914
That is your air injection system. The one way va... Feb 16 2023, 05:58 PM
JamesJ Dansk is currently in the development process of e... Feb 16 2023, 01:02 PM
rudedude Along the line of engine tin discussion are pieces... Feb 16 2023, 01:31 PM
914werke Along the line of engine tin discussion are piece... Feb 16 2023, 01:46 PM
914werke When you put the tin back on REMEMBER, pieces 5 a... Mar 17 2023, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 09:32 PM |
