> pressing in the front wheel bearings, what do I use, what do I grease?
914 RZ-1
post Feb 15 2023, 09:36 PM
Porsche Padawan
1. I need to press in the front wheel bearings. Can I just use a big socket and tap/hit them in? Is there a better way? I do not have a press.
2. What do I grease? I'm assuming a pack it in the bearings, but do I put grease anywhere else? Do I pack these before or after I press them in?
Thanks!
-Jeff
mgphoto
post Feb 16 2023, 11:37 AM
"If there is a mistake it will find me"
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important.
After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine.
930cabman
post Feb 16 2023, 11:47 AM
QUOTE(mgphoto @ Feb 16 2023, 12:37 PM) *
Exactly, make sure to clean the new bearing prior to greasing.
914 RZ-1   pressing in the front wheel bearings   Feb 15 2023, 09:36 PM
technicalninja   I'd scotch brite the new bearing bores and ins...   Feb 15 2023, 09:58 PM
iankarr   Hope this helps... https://www.youtube.com/watch?...   Feb 16 2023, 12:07 AM
914 RZ-1   Hope this helps... https://www.youtube.com/watch...   Feb 16 2023, 11:00 PM
scott_in_nh   The tool is obviously the best way, but if you use...   Feb 16 2023, 09:02 AM
technicalninja   The tool is obviously the best way, but if you us...   Feb 16 2023, 09:19 AM
BK911   Bearing races can be "pressed" in using ...   Feb 16 2023, 09:53 AM
mgphoto   You will need to press the grease into the bearing...   Feb 16 2023, 11:37 AM
930cabman   You will need to press the grease into the bearin...   Feb 16 2023, 11:47 AM
mgphoto   You will need to press the grease into the beari...   Feb 16 2023, 01:50 PM
914 RZ-1   You will need to press the grease into the bearin...   Feb 16 2023, 10:41 PM
mgphoto   [quote name='mgphoto' post='3058525' date='Feb 16...   Feb 17 2023, 06:23 PM
infraredcalvin   Nobody freezes these anymore? Prep the bearing an...   Feb 16 2023, 04:52 PM
Van B   Nobody freezes these anymore? Prep the bearing a...   Feb 16 2023, 10:58 PM
930cabman   Nobody freezes these anymore? Prep the bearing ...   Feb 17 2023, 06:02 AM
914 RZ-1   I removed the old ones from the late rotor, cut th...   Feb 17 2023, 05:40 PM
76-914   I removed the old ones from the late rotor, cut t...   Feb 17 2023, 10:30 PM
- Lo-Fi Version Time is now: 20th July 2025 - 07:12 PM
