> Aftermarket AC compressors
technicalninja
post Feb 15 2023, 09:19 AM
Does anyone have a modern compressor installed in a 914?
If so, I'd love more information on this.
I run a shop that specializes in automotive AC systems and my play-toys all have killer ac.
https://granburyautoac.com/
I'm planning a 134 conversion that uses a condenser behind the bumper and I need a modern compressor to make this work. The bumper has to be either a fiberglass replacement or something else (space reasons). I'll be using a modified 916 front cap.
The square York style needs to "leave the building"...
Any suggestions?
JamesJ
post Feb 16 2023, 02:35 PM
QUOTE(ClayPerrine @ Feb 15 2023, 07:45 AM) *
QUOTE(technicalninja @ Feb 15 2023, 09:19 AM) *
Any suggestions?
Ice Auto Air makes a compressor kit for the TypeIV VW engine. I have used it for years. It is a great, comprehensive kit that fits really well.
http://www.iceautoair.com
It bolts in the same place as the original York boat anchor and uses a serpentine belt to run the compressor.
Hope that helps!
@ClayPerrine
Clay, can you post a photo or two of your Ice Air compressor installed in your car?
I am curious if there are any weight differences between the Ice Air compressor and either a York or a Sanden(I have a Sanden).
My idle drops when I turn my a/c on, so my idle rpm is set a bit higher to accommodate.
For those with a/c, where are you pulling vacuum from to assist with this issue?
ClayPerrine
post Feb 16 2023, 04:11 PM
QUOTE(JamesJ @ Feb 16 2023, 02:35 PM) *
Any suggestions?
Hope that helps!
@ClayPerrine
The motor is not in the car. It was in our 914 that was hit. The body is in the body shop, and the motor is on a stand in the garage.
It is a lot lighter than the York compressor, and it doesn't pull as much horsepower.
To keep the idle speed up, I used a fuel tank switching solenoid from a Ford pickup plumbed in parallel with the decel valve. When the compressor is on, the valve is open. I put a restrictor in the line with a small hole in it, and kept enlarging the hole until the idle stayed steady when the compressor was on.
There is a picture of it somewhere on this site. Unfortunately, with the car disassembled and in the body shop, I don't have any way to take a picture of it.
Clay
technicalninja   Aftermarket AC compressors   Feb 15 2023, 09:19 AM
ClayPerrine   Does anyone have a modern compressor installed in...   Feb 15 2023, 09:45 AM
JamesJ   Does anyone have a modern compressor installed i...   Feb 16 2023, 02:31 PM
Jim C   Does anyone know of a source for rebuilt York boat...   Feb 15 2023, 01:10 PM
technicalninja   Yep. I use Yellow Rose rebuilders when I cannot bu...   Feb 15 2023, 01:27 PM
Jim C   Yep. I use Yellow Rose rebuilders when I cannot b...   Nov 16 2023, 07:36 AM
technicalninja   I go new OEM (commonly Denso) and donate all of my...   Feb 15 2023, 01:33 PM
technicalninja   Ice Auto Air makes a compressor kit for the Type...   Feb 15 2023, 01:51 PM
ClayPerrine   Ice Auto Air makes a compressor kit for the Typ...   Feb 15 2023, 02:50 PM
technicalninja   OH, thank you soooo much! Yes, I do want to s...   Feb 15 2023, 10:47 PM
Jeff_72   Im a newbie here, but this is my new favorite grou...   Feb 16 2023, 10:19 AM
ClayPerrine   Y'all need to come to Mayo Performance in Eule...   Feb 16 2023, 11:06 AM
technicalninja   My dad knew Zim and Mayo when they worked for Gree...   Feb 16 2023, 11:39 AM
JamesJ   Does anyone have a modern compressor installed i...   Feb 16 2023, 02:35 PM
ClayPerrine   [quote name='ClayPerrine' post='3058259' date='Fe...   Feb 16 2023, 04:11 PM
AZBanks   Still a work in progress. Buying a new house that ...   Feb 16 2023, 05:39 PM
burton73   Mark Sonners and I are trying to figure out an ele...   Nov 10 2023, 03:43 PM
Chris914n6   Wonder how I missed this thread. :sleep: Sande...   Nov 10 2023, 05:53 PM
technicalninja   Bob, whatever you do make sure the compressor is a...   Nov 10 2023, 08:52 PM
Chris914n6   The fans are only needed below 20 mph. If the fan...   Nov 10 2023, 10:44 PM
technicalninja   The fans are only needed below 20 mph. If the fa...   Nov 11 2023, 12:38 AM
Morrie   My favorite complaint is "turn this bitch do...   Nov 15 2023, 09:02 PM
friethmiller   My favorite complaint is "turn this bitch d...   Nov 16 2023, 02:46 PM
technicalninja   No I haven't yet. I'm a one-man shop (wif...   Nov 16 2023, 09:14 AM
friethmiller   Here's a pic of my compressor set-up prior to ...   Nov 16 2023, 02:54 PM
technicalninja   Here's a pic of my compressor set-up prior to...   Nov 16 2023, 03:13 PM
friethmiller   Here's a pic of my compressor set-up prior t...   Nov 16 2023, 03:48 PM
ClayPerrine   I plan on buying a new compressor and implementi...   Nov 16 2023, 04:28 PM
technicalninja   I'm reading that he has two cars... I would a...   Nov 16 2023, 04:42 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:45 PM
