Aefcaf |
Newbie ![]() Group: Members Posts: 18 Joined: 3-May 20 From: Ohio Member No.: 24,219 Region Association: MidAtlantic Region ![]() |
All, I know it has been discussed but I cannot find conclusive information on coolant tube or hoses running through the center tunnel. I ha e two 20ga 321S.S. 1.4" ID tu es that are perfect for my 20b rotary conversion. I'd like to run them through the tunnel and run right between the brace and steering rack with a bump kit installed giving me the extra10 mm of Clearance. Everything appears to fit. I.know I know the lines can be ran with green stripe underneath. I feel like that's home grown and can be fabricated with a much cleaner appearance.
1) has anyone successfully achieved using the tunnel for conversions? If so how warm does the car become? 2) where's did you.run the lines once on the other side of the firewall 3) concerns with heat soaking the steering rack? Attached thumbnail(s) ![]() |
Aefcaf |
Gang, I just cannot l stuff these tubes into the tunnel effectively. I plan to wrap the tunes in 1/2" thick Titan K insulation which really drops Temps. I wrapped the hose on my daily driver with it to play with the product and can comfortably hold the hose after fully warmed up. Impressive insulator. I hate to say this but I may need to rebuild the tunnel with a 4.5" total height vs 2" factory. Measured from rear of tunnel obviously. Ugh and other suggestion?
Lo-Fi Version | Time is now: 3rd September 2025 - 07:52 AM |
