914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
1. I need to press in the front wheel bearings. Can I just use a big socket and tap/hit them in? Is there a better way? I do not have a press.
2. What do I grease? I'm assuming a pack it in the bearings, but do I put grease anywhere else? Do I pack these before or after I press them in? ![]() ![]() Thanks! -Jeff --------- |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,656 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
Nobody freezes these anymore? Prep the bearing and put it in the freezer for a few days, take it out and quickly insert it into the rotor/hub. Tap in with socket or old race, etc. it will go in pretty easily.
Warm up the rotor hub a bit to make it easer but once the cold bearing hits the warm rotor it’ll start expanding quickly. |
Van B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None ![]() ![]() |
Nobody freezes these anymore? Prep the bearing and put it in the freezer for a few days, take it out and quickly insert it into the rotor/hub. Tap in with socket or old race, etc. it will go in pretty easily. Warm up the rotor hub a bit to make it easer but once the cold bearing hits the warm rotor it’ll start expanding quickly. (IMG:style_emoticons/default/agree.gif) I have a 20 ton shop press but I still prefer deep freeze overnight for the race and a little torch action or oven on the housing. Nothing more satisfying than that sound of a race dropping home with zero banging. |
Lo-Fi Version | Time is now: 20th July 2025 - 06:55 PM |
