914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
1. I need to press in the front wheel bearings. Can I just use a big socket and tap/hit them in? Is there a better way? I do not have a press.
2. What do I grease? I'm assuming a pack it in the bearings, but do I put grease anywhere else? Do I pack these before or after I press them in? ![]() ![]() Thanks! -Jeff --------- |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important.
After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. |
914 RZ-1 |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important. After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. Thanks! I think I get what to do. One questions/clarification: Why am I filling in between the hubs? There's nothing there, is there? Nothing rolls on the axle. Just curious? |
mgphoto |
You will need to press the grease into the bearing, there is a tool but it’s easy to pack it by hand. I use latex gloves, put a glob of grease in the palm of your hand, push the bearing into your palm, get another glob of grease with your fingers and rotate the bearing through your palm pushing the grease between the rollers and the cage, saturating the bearing is extremely important. After pressing in the races, fill the inner section of the hub, between the races with some grease, I use a moly lube called BR2, but most axle grease will work fine. Thanks! I think I get what to do. One questions/clarification: Why am I filling in between the hubs? There's nothing there, is there? Nothing rolls on the axle. Just curious? The heat in the hub will flow the grease from the center to the bearings, use just enough grease, use the rubber seals under the dust cap to contain the mess. |
Lo-Fi Version | Time is now: 20th July 2025 - 07:23 PM |
