> Which 911 oil tanks for a six?, can they even be used?
DougC
post Jan 18 2005, 04:42 PM
If not, what are my other options in a nutshell..don't want to read through those long post for info that might not be there. Also, what else will I need, filler neck and lid? stainless hoses, etc?
Doug C
michel richard
post Jan 19 2005, 01:48 PM
That's allright. I'll be happy to help with your conversion !
I have found that I could buy hydraulic hose that fits the stock hose fittings. I figure that these hoses don't see hundreds of pounds of pressure, certainly not thousands, so my own view is that it's easy to overkill and overspend in this area.
These hoses don't see tons of heat either. Normal oil temp is low two hundreds, and if it goes into the three hundreds, you've got a ton of other problems, in any event.
Michel
DougC   Which 911 oil tanks for a six?   Jan 18 2005, 04:42 PM
brant   None of the 911 ones will fit in the stock locatio...   Jan 18 2005, 04:46 PM
Mueller   yes, it can be used, but not in the original /6 lo...   Jan 18 2005, 04:46 PM
Cap'n Krusty   The 914/6 oil tank fits right, no 911 one fits, AF...   Jan 18 2005, 04:46 PM
DougC   thanks for clearing that up guys.. Doug C   Jan 18 2005, 05:06 PM
trekkor     Jan 18 2005, 08:40 PM
trekkor   Factory location is an easy choice... All holes ar...   Jan 18 2005, 08:51 PM
Dr Evil   You can get the odds and ends in the resources sec...   Jan 18 2005, 08:59 PM
JOHNMAN
  Jan 19 2005, 01:26 AM
michel richard   Doug, If you're doing a conversion, but can...   Jan 19 2005, 06:27 AM
joea9146   I thought the Hydraulic hoses did not like High He...   Jan 19 2005, 07:26 AM
JOHNMAN   I'll post a better pic when I get home tonight...   Jan 19 2005, 10:34 AM
neo914-6
  Jan 19 2005, 12:14 PM
DougC
  Jan 19 2005, 01:29 PM
michel richard   That's allright. I'll be happy to help wi...   Jan 19 2005, 01:48 PM
Root_Werks     Jan 19 2005, 03:06 PM
trekkor
  Jan 19 2005, 05:14 PM
Jeroen   anyone know if those Peterson tanks are available ...   Jan 19 2005, 06:14 PM
sixnotfour   http://www.petersonfluidsys.com/tanks.html -12 t...   Jan 19 2005, 06:47 PM
9146986   The only tanks I'd use would be the (priced as...   Jan 19 2005, 09:38 PM
JOHNMAN   What is the GPR tank as I am unfamiliar with it. ...   Jan 19 2005, 11:48 PM
neo914-6
  Jan 19 2005, 11:54 PM
trekkor
  Jan 20 2005, 12:08 AM
JOHNMAN   I said I would post a pic of an oil line with fitt...   Jan 20 2005, 12:39 AM
Kerrys914   http://www.914world.com/bbs2/html/e...   Jan 20 2005, 09:35 AM
JOHNMAN   Kerrys914, I'm sorry, I have forgotten what t...   Jan 20 2005, 11:21 PM
trekkor   I found the metric threaded -12AN fitting for the ...   Jan 20 2005, 11:57 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:38 PM
