Ignition options, I have issues please help me sort my ignition system |
CCE |
Feb 21 2023, 12:24 AM
CCE Group: Members Posts: 326 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
Superhawk996 |
Feb 21 2023, 08:10 AM
914 Guru Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Hmm - I’d talk to CB Performance. Their coil is low resistance and low impedance. It will pull A LOT of current. A lot more than a Bosch Blue coil. If they designed it for 1 ohm it’s up to them to make sure it can withstand the heat that it will generate.
Not liking 1 ohm primary at all for use with an old school distributor that has long dwell time (time the coil is energized). Low ohm coils like this usually serve only one or maybe two cylinders (in wasted spark application) fuel injection applications. In your application, this coil is trying to serve 4 cylinders. That means the coil is powered with a whole lot more “on” time than whatever application they took this coil from. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:28 AM |
