Redrilling early hubs for 5 lug.., different boss heights? |
bondo |
Jan 19 2005, 02:54 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I got me a set of early hubs. I am redrilling for 5 lugs, and don't want to screw this up. It looks to me that one of the original 4 lug bolt holes will need to become a stud hole, and then the other 4 stud holes will end up on a boss. The thing is the original threaded 4 lug bolt holes are through thicker bosses. Should I just mill down the one I'm using to the same height as the other bosses? Should I mill them all down to the same level? Should I leave it alone and have one stud stick out less?
(I have access to a mill and a degreed rotary table, so I'm not worried about alignment issues) |
Joe Bob |
Jan 19 2005, 04:25 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
OK..if you have five raised spots....mill them even, drill your holes and pull the studs thru. Use longer than stock ones if you have a choice. It allows the use of spacers if you have flares or want to set the wheels out more for a wider stance.
Lo-Fi Version | Time is now: 1st June 2024 - 07:17 PM |
