jcmatson |
Newbie ![]() Group: Members Posts: 4 Joined: 9-April 21 From: California Member No.: 25,414 Region Association: Southern California ![]() |
I have a 1974 that is experiencing shifting problems. The shifter will not easily slide into first. It will go into all other gears easily, but seems "blocked" from slotting into first. There is no gear grinding. If I shift into reverse first and then pull down it will go into 1st normally most the time. However, if I am trying to downshift from 2nd or above, the 1st gear position is blocked and the shift goes to 3rd gear. I am trying to understand if the problem is with the linkage, simple transmission mx like changing the gear oil or is it time for a rebuild. Thanks in advance for your insights.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,148 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Was she shifting good until recently? There is a series of connections from your right hand to the selector rod in the gearbox, often one or more of these connections gets weak (worn) Can you post pics of your ride? |
Lo-Fi Version | Time is now: 10th June 2024 - 07:06 AM |
