914 Transmission Shift Problem |
jcmatson |
Feb 23 2023, 01:04 PM
Newbie Group: Members Posts: 4 Joined: 9-April 21 From: California Member No.: 25,414 Region Association: Southern California |
I have a 1974 that is experiencing shifting problems. The shifter will not easily slide into first. It will go into all other gears easily, but seems "blocked" from slotting into first. There is no gear grinding. If I shift into reverse first and then pull down it will go into 1st normally most the time. However, if I am trying to downshift from 2nd or above, the 1st gear position is blocked and the shift goes to 3rd gear. I am trying to understand if the problem is with the linkage, simple transmission mx like changing the gear oil or is it time for a rebuild. Thanks in advance for your insights.
emerygt350 |
Feb 23 2023, 02:18 PM
Advanced Member Group: Members Posts: 2,132 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Sounds like a Porsche.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:28 AM |
