tacos anyone?, taco plate problem |
doobie123 |
Feb 28 2023, 01:45 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi ya'll
working on my 75, 2.0 5spd and i'm having a issue with the taco plate. the car had a plug in the plate where the sensor goes so i want to put a sensor in. got a new sensor, gasket, and o ring from auto atlanta,(thanks george and albert) and when i put the sensor on the plate, i discovered that it wont fit in the space where it should go into the sump. i've enclosed a few pics of the parts i.m dealing with and also a shot of where the sensor is hitting the inside of the sump. i know it should go in pointing in the direction of the crank but, it won't fit in either direction. so whats wrong? can i cut the sensor to make it fit or space it so there is more clearence? none of those sound right but maybe thats it? anyway, any help would be great. thanks Attached thumbnail(s) |
technicalninja |
Feb 28 2023, 07:42 PM
Senior Member Group: Members Posts: 1,290 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
I have the o ring and the paper gasket and George from AA is gonna find me a cover. So the o ring doesn't seem to make a difference? What's your idea? Dont spend more to find the cover, replace it HERE. You just need the plate vs the assembly as you can use the existing sender.(IMG:style_emoticons/default/happy11.gif) As was mentioned you may just have it 180 out. But... I just pulled one of these out of a 73 2.0 and it is identical to what is in the picture, dent and all. I prefer 914werke's Taco plate as well but what's pictured should have been installable. It is not installed backwards either. My unit's sensing element (inside case) goes into a large recess and is pointing towards the flywheel. I believe the pictured plate has been overtightened in the past and is bent upwards at the bolt holes. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:55 AM |
