| second wind |
Mar 2 2023, 12:56 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
Changing out all fuel lines due to constant leaks....want to use SAE 30 R9 as recommended but not finding the real deal by Gates or Continental....please advise where to buy the real deal....live in Los Angeles California...thank you very much!
gg |
| 76-914 |
Mar 2 2023, 08:19 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,870 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
The 911 folks have some anecdotal reports of failure in cars with infrequent usage. One possibility is e10 fuel suffering from phase separation and effectively becoming e100 at low points, I don’t know enough to speak with real authority. Looking at various fuel line lately, and even the carb stuff appears to have enough pressure rating for jetronic injection. Here’s the discussion over on Pelican: http://forums.pelicanparts.com/porsche-911...-fuel-hose.html For the record - I am no fan of ethanol. However, when the phase separation occurs you do not get E100. What you have is ethanol molecules bonded to water molecules. Up to 3 water molecules can bind to a single ethanol molecule. So what you have is a mix of ethanol bound to water. That combined molecule has higher density than gasoline, therefore it falls out of suspension and sinks. But let’s be clear, it is not E100. more like E50 if we have 1 molecule of water combining with 1 molecule of water. Even less if we got the full 3 molecules of water bonding to each molecule of ethanol. Somewhere in chemistry I probably learned how to calculate this better but honestly I was never great at chemistry and became a mechanical engineer. Chemical engineers get paid way more - I screwed up. (IMG:style_emoticons/default/laugh.gif) There is quite a bit of debate as to whether this ethanol water mix is effective at attacking elastomers like hose as is the E10 alcohol dissolved in the gasoline. Clearly the water that is in the tank or bonded with the ethanol is still able to attack and corrode metals. Not a good thing. Let’s also put numbers to this. 20 gallons of E10 can hold about 0.6 pint of water per 20 gallons of gasoline E10 mix. Next time you are at Home Depot, look at the size of a 1/2 pint can of stain. Now imagine that as a percentage of the 16 gallon tank in a 914. Don’t get me wrong, I don’t want that in my tank but it’s a relatively small amount and that only results IF you get 100% phase separation. Phase separation needs water in the tank to occur. Store your gas tank full to minimize the amount of condensation (from ambient humidity) that can get in your gas which can then begin the phase separation process. This is not new, even if you have pure gasoline, you can still get ambient humidity condensing easily in a metal tank. You will still end up with water at the bottom of your gas tank. Not good. Moral of the story, store your tank full of ethanol free gasoline if possible. Regardless of what is in the tank - make sure it is full. This is why GA pilots always take a sample off each tank during pre-flight inspection. (IMG:style_emoticons/default/beerchug.gif) |
second wind Can't find SAE 30 R9 fuel line....Where to buy? Mar 2 2023, 12:56 AM
Mikey914 Pelican? Relatively "local" Mar 2 2023, 01:10 AM
Superhawk996 Amazon - buy Continental hose in bulk 25’ roll a... Mar 2 2023, 05:57 AM
JamesM
Changing out all fuel lines due to constant leaks... Mar 2 2023, 09:27 AM
Superhawk996
Changing out all fuel lines due to constant leak... Mar 2 2023, 09:52 AM
VaccaRabite R9 is really flexible. Like so flexible it tends ... Mar 2 2023, 01:27 PM
mb911 I guess I didn’t realize there was so many diffe... Mar 2 2023, 02:32 PM
zoomCat The 911 folks have some anecdotal reports of failu... Mar 2 2023, 06:08 PM
Superhawk996
The 911 folks have some anecdotal reports of fail... Mar 2 2023, 06:47 PM
r_towle Moral of the story,
Always ask the mechanical engi... Mar 2 2023, 07:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 03:09 AM |
