| Deusexmachina77 |
Mar 3 2023, 03:57 PM
Member ![]() ![]() Group: Members Posts: 100 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest
| davep |
Mar 3 2023, 06:58 PM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,373 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Many front calipers use the Banjo connection for a right angle direction change. It has a hollow bolt with 2 different copper washers and the brass banjo.
![]() Your pad installation looks correct, the pins have a compressible collar that holds them in place. The caliper looks to be just sandblasted but not plated or painted. It should at least be rattle can painted with high temperature paint to keep the rusting down or the pads will rust into place. |
| Deusexmachina77 |
Mar 3 2023, 07:13 PM
Many front calipers use the Banjo connection for a right angle direction change. It has a hollow bolt with 2 different copper washers and the brass banjo. ![]() Your pad installation looks correct, the pins have a compressible collar that holds them in place. The caliper looks to be just sandblasted but not plated or painted. It should at least be rattle can painted with high temperature paint to keep the rusting down or the pads will rust into place. Thank you for the photo. Now it makes sense. Not to be a complete idiot, but do I paint the inside as well and mask off the piston area? |
Deusexmachina77 Front Brakes Mar 3 2023, 03:57 PM
mepstein The brake line used a banjo bolt Mar 3 2023, 04:05 PM
Deusexmachina77
I removed a str... Mar 3 2023, 05:19 PM
mepstein The connection from the hardline to the caliper is... Mar 3 2023, 06:42 PM
r_towle
Many front calipers use the Banjo connection for... Mar 3 2023, 08:14 PM
Deusexmachina77 I guess I didn't think to look for something e... Mar 3 2023, 07:09 PM
mgphoto The items you need are listed in the PET
Num... Mar 3 2023, 07:11 PM
Deusexmachina77
Nu... Mar 3 2023, 07:27 PM
914 RZ-1 I'm having a similar issue: I want the brake l... Mar 5 2023, 12:41 PM
willieg I had a similar problem with two calipers I purcha... Mar 5 2023, 06:35 PM
914 RZ-1
I had a similar problem with two calipers I purch... Mar 5 2023, 09:23 PM
Mike D. 914 RZ-1 is Right.
The later front caliper, 73 on... Mar 6 2023, 12:45 AM
Eric_Shea As per Mike's post, you have a late caliper an... Mar 6 2023, 09:03 AM
914 RZ-1 Thanks, Mike D. and @Eric_Shea .
I called PMB an... Mar 6 2023, 08:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th August 2026 - 05:09 AM |
