| Deusexmachina77 |
Mar 3 2023, 03:57 PM
Member ![]() ![]() Group: Members Posts: 100 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest
| mgphoto |
Mar 3 2023, 07:11 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
| Deusexmachina77 |
Mar 3 2023, 07:27 PM
Deusexmachina77 Front Brakes Mar 3 2023, 03:57 PM
mepstein The brake line used a banjo bolt Mar 3 2023, 04:05 PM
Deusexmachina77
I removed a str... Mar 3 2023, 05:19 PM
mepstein The connection from the hardline to the caliper is... Mar 3 2023, 06:42 PM
davep Many front calipers use the Banjo connection for a... Mar 3 2023, 06:58 PM
Deusexmachina77
Many front calipers use the Banjo connection for ... Mar 3 2023, 07:13 PM
r_towle
Many front calipers use the Banjo connection for... Mar 3 2023, 08:14 PM
Deusexmachina77 I guess I didn't think to look for something e... Mar 3 2023, 07:09 PM
914 RZ-1 I'm having a similar issue: I want the brake l... Mar 5 2023, 12:41 PM
willieg I had a similar problem with two calipers I purcha... Mar 5 2023, 06:35 PM
914 RZ-1
I had a similar problem with two calipers I purch... Mar 5 2023, 09:23 PM
Mike D. 914 RZ-1 is Right.
The later front caliper, 73 on... Mar 6 2023, 12:45 AM
Eric_Shea As per Mike's post, you have a late caliper an... Mar 6 2023, 09:03 AM
914 RZ-1 Thanks, Mike D. and @Eric_Shea .
I called PMB an... Mar 6 2023, 08:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th August 2026 - 05:12 AM |
