| DougC |
Jan 18 2005, 04:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
If not, what are my other options in a nutshell..don't want to read through those long post for info that might not be there. Also, what else will I need, filler neck and lid? stainless hoses, etc?
Doug C |
| IronHillRestorations |
Jan 19 2005, 09:38 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
The only tanks I'd use would be the (priced as though they are gold plated) factory tanks or the aluminum fabricated tanks that GPR makes. The GPR tank is the lightest oil tank made for a 914-6, uses factory fitings or AN, and bolts up in the stock location. You can use all the factory tank boots, which makes for a very clean install. The factory filler neck fits perfectly too.
I think Veli-hose is out of business, which is just as well. The cast aluminum tanks have some advantages, but are heavy, and then there is lack of customer support, blah, blah. You can't use the factory boots, and they don't fit against the inner fender as well as the factory tanks, or the GPR tank. Also the factory filler neck doesn't fit right either. Yes you can use a aftermarket "generic" tank, and many have done so sucessfully. My opinion is that in the overall scheme of a six conversion, a few hundred dollars more for a oil tank that fits right is spit on the griddle. The dry sump system is the life blood of your six engine so be sure you do it properly. |
DougC Which 911 oil tanks for a six? Jan 18 2005, 04:42 PM
brant None of the 911 ones will fit in the stock locatio... Jan 18 2005, 04:46 PM
Mueller yes, it can be used, but not in the original /6 lo... Jan 18 2005, 04:46 PM
Cap'n Krusty The 914/6 oil tank fits right, no 911 one fits, AF... Jan 18 2005, 04:46 PM
DougC thanks for clearing that up guys..
Doug C Jan 18 2005, 05:06 PM
trekkor ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:39 PM |
