| Deusexmachina77 |
Mar 3 2023, 03:57 PM
Member ![]() ![]() Group: Members Posts: 100 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest
| 914 RZ-1 |
Mar 5 2023, 12:41 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
I'm having a similar issue: I want the brake line have a bend in it that allows it to go into the caliper without a banjo bolt. If you look at the PET, there are 2 hard lines that go into the front calipers. One has the 90° bend, the other does not and requires the banjo.
#11 is for cars up thru 1971 and #12 is for cars with VIN 19032 and later, if I'm reading the PET correctly. I bought what I thought were the correct hard lines from PMB, but they are the same as #11, even though my order was indicated as #12. I could not easily find the banjo bolt and other parts on PMB's site. I will be calling them on Monday top get some clarification. |
Deusexmachina77 Front Brakes Mar 3 2023, 03:57 PM
mepstein The brake line used a banjo bolt Mar 3 2023, 04:05 PM
Deusexmachina77
I removed a str... Mar 3 2023, 05:19 PM
mepstein The connection from the hardline to the caliper is... Mar 3 2023, 06:42 PM
davep Many front calipers use the Banjo connection for a... Mar 3 2023, 06:58 PM
Deusexmachina77
Many front calipers use the Banjo connection for ... Mar 3 2023, 07:13 PM
r_towle
Many front calipers use the Banjo connection for... Mar 3 2023, 08:14 PM
Deusexmachina77 I guess I didn't think to look for something e... Mar 3 2023, 07:09 PM
mgphoto The items you need are listed in the PET
Num... Mar 3 2023, 07:11 PM
Deusexmachina77
Nu... Mar 3 2023, 07:27 PM
willieg I had a similar problem with two calipers I purcha... Mar 5 2023, 06:35 PM
914 RZ-1
I had a similar problem with two calipers I purch... Mar 5 2023, 09:23 PM
Mike D. 914 RZ-1 is Right.
The later front caliper, 73 on... Mar 6 2023, 12:45 AM
Eric_Shea As per Mike's post, you have a late caliper an... Mar 6 2023, 09:03 AM
914 RZ-1 Thanks, Mike D. and @Eric_Shea .
I called PMB an... Mar 6 2023, 08:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th August 2026 - 05:11 AM |
