| bossboy302 |
Mar 3 2023, 02:07 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
Sorry for re-asking this, but as I begin fiddling with mechanical and electrical components for my project 6 conversion, I am still pondering this decision.
The car, when finished, will be shipped to Europe where my wife and I can use it when we're there, and do some rallies, trips and such. There will likely be (months-long) periods of no use. Have most of the necessary stuff for the build, (included with the '71E motor-entire MFI, fuel filter/console, complete electrical board, fuel pump, etc) all from 'donor' car... But I'm beginning to sense that the complexity of MFI (transducers, fuel system, micro-switches, etc.) could prove challenging. A good set of PMO's on the other hand: basic fuel pump and regulator, MSD 6AL, and a spray can of ether may be better suited, again given the intended use. So, I welcome thoughts and opinions-thanks |
| peteinjp |
Mar 6 2023, 08:48 PM
Member ![]() ![]() Group: Members Posts: 212 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None
I’m in the other camp. If you have all the Mfi stuff and your engine configuration is stock and you have someone that can test and set it up properly you’ll never need to touch it. It can sit for extended periods of time without needing to be rebuilt like a carb. But- you need to replace all the old stuff including things like the cold start injectors etc. IF you have some one that can bring it up to “as new” standards it’s the best.
The cold start injection system can by used with a simple push button so that eliminates one electrical component. The microswitch system is not necessary. I have had mine disconnected the only difference is that it saves fuel on deceleration- so that’s another simplification. Then basically you have the thermostat, altitude compensator (an advantage over carbs) and those are both mechanical systems which are very well documented online. So- if you have the right person to set it up- someone that has done it many times and you can afford the initial cost of pump rebuilds etc go for the better system. Pete |
bossboy302 MFI or carbs? Mar 3 2023, 02:07 PM
Superhawk996 MFI is amazing tech for that era. However, hard t... Mar 3 2023, 02:22 PM
Long_ago Agreed.
I went with new webers on my 6. For the si... Mar 3 2023, 02:32 PM
Cairo94507 I 100% agree; you can always swap out to MFI when ... Mar 3 2023, 02:34 PM
r_towle Add in a fuel shutoff (look at the 356) so when yo... Mar 3 2023, 02:44 PM
ClayPerrine You should consider an aftermarket EFI setup.
Mo... Mar 3 2023, 02:50 PM
NARP74 I am guessing the newer EFI systems will cost ... Mar 3 2023, 02:55 PM
mlindner bossboy302. Living in Wisconsin, time on the road ... Mar 4 2023, 08:03 AM
targa72e Mfi once set up requires very little attention. If... Mar 5 2023, 11:22 PM
ClayPerrine
On of the other issues with MFI is that 914 has... Mar 6 2023, 06:35 AM
vitamin914 On my carbed '74 914-4 I have a switch to the ... Mar 6 2023, 08:22 AM
Eric_Shea Modern EFI that looks like carbs. ;)
https://pmbp... Mar 6 2023, 01:08 PM
Superhawk996 EFI is nice and all but that wasn’t what OP aske... Mar 6 2023, 01:37 PM
Eric_Shea OK, OK... Carbs to the OP?
ECU is Holley. Holley... Mar 6 2023, 02:01 PM
ClayPerrine
ECU is Holley. Holle... Mar 6 2023, 02:27 PM
Superhawk996
ECU is Holley. Holle... Mar 6 2023, 04:13 PM
r_towle Honestly, it does bring up an interesting reality.... Mar 6 2023, 05:13 PM
930cabman My vote goes to Webers. Mar 6 2023, 05:20 PM
r_towle
I’m in the same camp t... Mar 6 2023, 05:24 PM
ClayPerrine
I’m in the same camp today,,, until I learn mor... Mar 7 2023, 06:41 AM
Superhawk996
Dead stock carbs. Well maintained. Driven reg... Mar 7 2023, 07:46 AM
JmuRiz I’m lucky enough to have EFI, MFI and carb exper... Mar 6 2023, 07:55 PM
bossboy302 O P here-first, thank you all for contributing gre... Mar 7 2023, 10:09 AM
NARP74 For the Jenvey carbs, is that price per, or for a ... Mar 7 2023, 09:11 AM
ClayPerrine
For the Jenvey carbs, is that price per, or for a... Mar 7 2023, 09:58 AM
Eric_Shea
[quote name='NARP74' post='3063118' date='Mar 7 2... Mar 8 2023, 01:03 PM
horizontally-opposed
Also the Jenvey will fit common IDF/IDA air clean... Mar 8 2023, 06:25 PM
ClayPerrine There is a lot to be said for the simplicity of ca... Mar 7 2023, 09:54 AM
Superhawk996
Another advantage to EFI is that professional he... Mar 7 2023, 10:14 AM
ClayPerrine
Another advantage to EFI is that professional h... Mar 7 2023, 10:27 AM
Superhawk996
[quote name='Superhawk996' post='3063130' date='M... Mar 7 2023, 10:47 AM
r_towle
[quote name='Superhawk996' post='3063130' date='... Mar 7 2023, 11:09 AM
ClayPerrine
I will say, I learned on new term here.
Percussiv... Mar 7 2023, 12:08 PM
dr914@autoatlanta.com if the mfi is matched (T E and S are all different... Mar 7 2023, 12:38 PM
ClayPerrine Another thing to consider is the location where th... Mar 7 2023, 03:38 PM
bossboy302 Great point!
So with permission, I'll star... Mar 7 2023, 04:23 PM
r_towle Somewhere here is an old thread of a couple who sh... Mar 7 2023, 06:49 PM
Superhawk996 Register stateside and get an EU Carnet to bring i... Mar 7 2023, 07:52 PM
roundtwo @ClayPerrine
@bossboy320
Good point about emissio... Mar 8 2023, 01:21 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 8 2023, 06:02 AM
peteinjp
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 8 2023, 03:47 AM
ClayPerrine
MFI has altitude adjustment...
Just sayin.
Pet... Mar 8 2023, 06:30 AM
JmuRiz :idea: Mar 8 2023, 04:51 PM
Eric_Shea Not yet Pete. Bob's was the early Sport air f... Mar 8 2023, 07:09 PM
Not yet Pete. Bob's was the early Sport air ... Mar 9 2023, 03:49 PM
Superhawk996 :hijacked:
OP asks A or B
Answer - you need ... Mar 8 2023, 07:14 PM
Steve
:hijacked: :evilgrin:
:deadhorse:
Tons of in... Mar 8 2023, 07:17 PM
Eric_Shea Ooooooooooooooops! Thread police! :lol:
... Mar 8 2023, 07:33 PM
Superhawk996 Thread police here :cop: It’s all in good fun... Mar 9 2023, 04:18 PM
tygaboy In case anyone cares: my main gripe with Holley EC... Mar 9 2023, 04:35 PM
Superhawk996
In case anyone cares: my main gripe with Holley E... Mar 9 2023, 06:57 PM
tygaboy
In case anyone cares: my main gripe with Holley ... Mar 9 2023, 07:14 PM
Eric_Shea
True dat. This is one of the reasons our builds... Mar 13 2023, 01:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 04:18 PM |
