| bossboy302 |
Mar 3 2023, 02:07 PM
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
Sorry for re-asking this, but as I begin fiddling with mechanical and electrical components for my project 6 conversion, I am still pondering this decision.
The car, when finished, will be shipped to Europe where my wife and I can use it when we're there, and do some rallies, trips and such. There will likely be (months-long) periods of no use. Have most of the necessary stuff for the build, (included with the '71E motor-entire MFI, fuel filter/console, complete electrical board, fuel pump, etc) all from 'donor' car... But I'm beginning to sense that the complexity of MFI (transducers, fuel system, micro-switches, etc.) could prove challenging. A good set of PMO's on the other hand: basic fuel pump and regulator, MSD 6AL, and a spray can of ether may be better suited, again given the intended use. So, I welcome thoughts and opinions-thanks |
| 930cabman |
Mar 6 2023, 05:20 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,531 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
My vote goes to Webers.
| r_towle |
Mar 6 2023, 05:24 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
| ClayPerrine |
Mar 7 2023, 06:41 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I’m in the same camp today,,, until I learn more. At the end of the day, what can realistically go wrong with carbs? Not much. https://www.youtube.com/watch?v=tP1PPjOJLgY Dead stock carbs. Well maintained. Driven regularly. Stuck float. Hydrolocked. Face full of gas. I am considering these for Elwood. https://store.jenvey.co.uk/throttle-body-ki...ottle-body-42mm Hide everything under the air cleaner. It would look stock and run way better. And it will be fully reversible and I will keep the stock carbs and fuel pump in case the next owner wants to go back to them. |
| Superhawk996 |
Mar 7 2023, 07:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,734 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Dead stock carbs. Well maintained. Driven regularly. Stuck float. Hydrolocked. Face full of gas. Though unfortunate - it was fixed with no special tools, no EFI expertise with a cobbled aftermarket EFI, or parts that could be hard to obtain in a pinch. Sort of makes the case why carbs might be a good option for the OP’s purpose. (IMG:style_emoticons/default/biggrin.gif) I’ve got a carb sitting outside on a 1948 Case tractor. 75 years old and still working. Starts in below zero weather with nothing more than a pull of the hand choke. Again, I love EFI . . . But carbs have been around for more than 100 years and they work without ECU’s, laptops to tune or diagnose, or external electronic sensing that can bring other failure modes. Let’s not forget that on a modern car, a failed crank sensor leaves you walking with no hope of a roadside fix. Does it happen? Not often… but it does happen. I’ve seen the warranty data at two different OEMs so I know that it happens, and how unhappy customers are when it happens. There is no denying that EFI occasionally fails, just as there is no denying that your carb float stuck. It’s about about tradeoffs that only the OP can make. Hopefully, the varied points of view and the lively debate are appreciated. |
bossboy302 MFI or carbs? Mar 3 2023, 02:07 PM
Superhawk996 MFI is amazing tech for that era. However, hard t... Mar 3 2023, 02:22 PM
Long_ago Agreed.
I went with new webers on my 6. For the si... Mar 3 2023, 02:32 PM
Cairo94507 I 100% agree; you can always swap out to MFI when ... Mar 3 2023, 02:34 PM
r_towle Add in a fuel shutoff (look at the 356) so when yo... Mar 3 2023, 02:44 PM
ClayPerrine You should consider an aftermarket EFI setup.
Mo... Mar 3 2023, 02:50 PM
NARP74 I am guessing the newer EFI systems will cost ... Mar 3 2023, 02:55 PM
mlindner bossboy302. Living in Wisconsin, time on the road ... Mar 4 2023, 08:03 AM
targa72e Mfi once set up requires very little attention. If... Mar 5 2023, 11:22 PM
ClayPerrine
On of the other issues with MFI is that 914 has... Mar 6 2023, 06:35 AM
vitamin914 On my carbed '74 914-4 I have a switch to the ... Mar 6 2023, 08:22 AM
Eric_Shea Modern EFI that looks like carbs. ;)
https://pmbp... Mar 6 2023, 01:08 PM
Superhawk996 EFI is nice and all but that wasn’t what OP aske... Mar 6 2023, 01:37 PM
Eric_Shea OK, OK... Carbs to the OP?
ECU is Holley. Holley... Mar 6 2023, 02:01 PM
ClayPerrine
ECU is Holley. Holle... Mar 6 2023, 02:27 PM
Superhawk996
ECU is Holley. Holle... Mar 6 2023, 04:13 PM
r_towle Honestly, it does bring up an interesting reality.... Mar 6 2023, 05:13 PM
JmuRiz I’m lucky enough to have EFI, MFI and carb exper... Mar 6 2023, 07:55 PM
bossboy302 O P here-first, thank you all for contributing gre... Mar 7 2023, 10:09 AM
peteinjp I’m in the other camp. If you have all the Mfi s... Mar 6 2023, 08:48 PM
NARP74 For the Jenvey carbs, is that price per, or for a ... Mar 7 2023, 09:11 AM
ClayPerrine
For the Jenvey carbs, is that price per, or for a... Mar 7 2023, 09:58 AM
Eric_Shea
[quote name='NARP74' post='3063118' date='Mar 7 2... Mar 8 2023, 01:03 PM
horizontally-opposed
Also the Jenvey will fit common IDF/IDA air clean... Mar 8 2023, 06:25 PM
ClayPerrine There is a lot to be said for the simplicity of ca... Mar 7 2023, 09:54 AM
Superhawk996
Another advantage to EFI is that professional he... Mar 7 2023, 10:14 AM
ClayPerrine
Another advantage to EFI is that professional h... Mar 7 2023, 10:27 AM
Superhawk996
[quote name='Superhawk996' post='3063130' date='M... Mar 7 2023, 10:47 AM
r_towle
[quote name='Superhawk996' post='3063130' date='... Mar 7 2023, 11:09 AM
ClayPerrine
I will say, I learned on new term here.
Percussiv... Mar 7 2023, 12:08 PM
dr914@autoatlanta.com if the mfi is matched (T E and S are all different... Mar 7 2023, 12:38 PM
ClayPerrine Another thing to consider is the location where th... Mar 7 2023, 03:38 PM
bossboy302 Great point!
So with permission, I'll star... Mar 7 2023, 04:23 PM
r_towle Somewhere here is an old thread of a couple who sh... Mar 7 2023, 06:49 PM
Superhawk996 Register stateside and get an EU Carnet to bring i... Mar 7 2023, 07:52 PM
roundtwo @ClayPerrine
@bossboy320
Good point about emissio... Mar 8 2023, 01:21 AM
930cabman
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 8 2023, 06:02 AM
peteinjp
[b]@[url=http://www.914world.com/bbs2/index.php?s... Mar 8 2023, 03:47 AM
ClayPerrine
MFI has altitude adjustment...
Just sayin.
Pet... Mar 8 2023, 06:30 AM
JmuRiz :idea: Mar 8 2023, 04:51 PM
Eric_Shea Not yet Pete. Bob's was the early Sport air f... Mar 8 2023, 07:09 PM
Not yet Pete. Bob's was the early Sport air ... Mar 9 2023, 03:49 PM
Superhawk996 :hijacked:
OP asks A or B
Answer - you need ... Mar 8 2023, 07:14 PM
Steve
:hijacked: :evilgrin:
:deadhorse:
Tons of in... Mar 8 2023, 07:17 PM
Eric_Shea Ooooooooooooooops! Thread police! :lol:
... Mar 8 2023, 07:33 PM
Superhawk996 Thread police here :cop: It’s all in good fun... Mar 9 2023, 04:18 PM
tygaboy In case anyone cares: my main gripe with Holley EC... Mar 9 2023, 04:35 PM
Superhawk996
In case anyone cares: my main gripe with Holley E... Mar 9 2023, 06:57 PM
tygaboy
In case anyone cares: my main gripe with Holley ... Mar 9 2023, 07:14 PM
Eric_Shea
True dat. This is one of the reasons our builds... Mar 13 2023, 01:47 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 04:18 PM |
