> MFI or carbs?
bossboy302
post Mar 3 2023, 02:07 PM
Sorry for re-asking this, but as I begin fiddling with mechanical and electrical components for my project 6 conversion, I am still pondering this decision.
The car, when finished, will be shipped to Europe where my wife and I can use it when we're there, and do some rallies, trips and such. There will likely be (months-long) periods of no use.
Have most of the necessary stuff for the build, (included with the '71E motor-entire MFI, fuel filter/console, complete electrical board, fuel pump, etc) all from 'donor' car...
But I'm beginning to sense that the complexity of MFI (transducers, fuel system, micro-switches, etc.) could prove challenging. A good set of PMO's on the other hand: basic fuel pump and regulator, MSD 6AL, and a spray can of ether may be better suited, again given the intended use.
So, I welcome thoughts and opinions-thanks
NARP74
post Mar 7 2023, 09:11 AM
For the Jenvey carbs, is that price per, or for a pair? Ouch, that is pricey and I may have to upgrade my original estimate on price, a lot. Add a controller and all the other bits and bobs you need, it becomes very expensive. I do understand the allure of EFI though, especially after a face full of petrol.
ClayPerrine
post Mar 7 2023, 09:58 AM
QUOTE(NARP74 @ Mar 7 2023, 09:11 AM) *
The Jenvy throttle bodies are designed to look like carbs. Most throttle bodies are way cheaper, but they don't look like carbs.
PMO throttle bodies are blatantly throttle bodies and do nothing to hide it. They are probably better throttle bodies than the Jenvey ones. What you are paying for with the Jenvey ones is the stealth factor.
Eric_Shea
post Mar 8 2023, 01:03 PM
PMB Performance
QUOTE(ClayPerrine @ Mar 7 2023, 08:58 AM) *
We sell both the PMO and the Jenvey. Both are of the same quality. Jenvey is top notch.
Also the Jenvey will fit common IDF/IDA air cleaners, run standard IDF/IDA linkage, fit IDF/IDA manifolds, has PICO fuel injectors included, had TPS (throttle position sensor) included, has fuel rails included. We went down this road with Borla as an example... once you got all of the other parts, the price shot up there and, custom air filter bases had to be fabricated.
Price adjusted yesterday to meet current exchange rate. (IMG:style_emoticons/default/wink.gif)
ALSOOOO... here's a lower cost set if you already have the manifolds and linkage:
https://pmbperformance.com/products/jenvey-...-ida3-42mm-pair
horizontally-opposed
post Mar 8 2023, 06:25 PM
QUOTE(Eric_Shea @ Mar 8 2023, 11:03 AM) *
Those heritage Jenveys are (IMG:style_emoticons/default/drooley.gif)
Eric, have you done this under a factory airbox/filter housing yet? Already have crank-fire ignition, so this is pretty interesting.
bossboy302   MFI or carbs?   Mar 3 2023, 02:07 PM
Superhawk996   MFI is amazing tech for that era. However, hard t...   Mar 3 2023, 02:22 PM
Long_ago   Agreed. I went with new webers on my 6. For the si...   Mar 3 2023, 02:32 PM
Cairo94507   I 100% agree; you can always swap out to MFI when ...   Mar 3 2023, 02:34 PM
r_towle   Add in a fuel shutoff (look at the 356) so when yo...   Mar 3 2023, 02:44 PM
ClayPerrine   You should consider an aftermarket EFI setup. Mo...   Mar 3 2023, 02:50 PM
NARP74   I am guessing the newer EFI systems will cost ...   Mar 3 2023, 02:55 PM
mlindner   bossboy302. Living in Wisconsin, time on the road ...   Mar 4 2023, 08:03 AM
targa72e   Mfi once set up requires very little attention. If...   Mar 5 2023, 11:22 PM
ClayPerrine   On of the other issues with MFI is that 914 has...   Mar 6 2023, 06:35 AM
vitamin914   On my carbed '74 914-4 I have a switch to the ...   Mar 6 2023, 08:22 AM
Eric_Shea   Modern EFI that looks like carbs. ;) https://pmbp...   Mar 6 2023, 01:08 PM
Superhawk996   EFI is nice and all but that wasn’t what OP aske...   Mar 6 2023, 01:37 PM
Eric_Shea   OK, OK... Carbs to the OP? ECU is Holley. Holley...   Mar 6 2023, 02:01 PM
ClayPerrine   OK, OK... Carbs to the OP? ECU is Holley. Holle...   Mar 6 2023, 02:27 PM
Superhawk996   OK, OK... Carbs to the OP? ECU is Holley. Holle...   Mar 6 2023, 04:13 PM
r_towle   Honestly, it does bring up an interesting reality....   Mar 6 2023, 05:13 PM
930cabman   My vote goes to Webers.   Mar 6 2023, 05:20 PM
r_towle   My vote goes to Webers. I’m in the same camp t...   Mar 6 2023, 05:24 PM
ClayPerrine   I’m in the same camp today,,, until I learn mor...   Mar 7 2023, 06:41 AM
Superhawk996   Dead stock carbs. Well maintained. Driven reg...   Mar 7 2023, 07:46 AM
JmuRiz   I’m lucky enough to have EFI, MFI and carb exper...   Mar 6 2023, 07:55 PM
bossboy302   O P here-first, thank you all for contributing gre...   Mar 7 2023, 10:09 AM
peteinjp   I’m in the other camp. If you have all the Mfi s...   Mar 6 2023, 08:48 PM
NARP74   For the Jenvey carbs, is that price per, or for a ...   Mar 7 2023, 09:11 AM
ClayPerrine   For the Jenvey carbs, is that price per, or for a...   Mar 7 2023, 09:58 AM
Eric_Shea   [quote name='NARP74' post='3063118' date='Mar 7 2...   Mar 8 2023, 01:03 PM
horizontally-opposed   Also the Jenvey will fit common IDF/IDA air clean...   Mar 8 2023, 06:25 PM
ClayPerrine   There is a lot to be said for the simplicity of ca...   Mar 7 2023, 09:54 AM
Superhawk996   Another advantage to EFI is that professional he...   Mar 7 2023, 10:14 AM
ClayPerrine   Another advantage to EFI is that professional h...   Mar 7 2023, 10:27 AM
Superhawk996   [quote name='Superhawk996' post='3063130' date='M...   Mar 7 2023, 10:47 AM
r_towle   [quote name='Superhawk996' post='3063130' date='...   Mar 7 2023, 11:09 AM
ClayPerrine   I will say, I learned on new term here. Percussiv...   Mar 7 2023, 12:08 PM
dr914@autoatlanta.com   if the mfi is matched (T E and S are all different...   Mar 7 2023, 12:38 PM
ClayPerrine   Another thing to consider is the location where th...   Mar 7 2023, 03:38 PM
bossboy302   Great point! So with permission, I'll star...   Mar 7 2023, 04:23 PM
r_towle   Somewhere here is an old thread of a couple who sh...   Mar 7 2023, 06:49 PM
Superhawk996   Register stateside and get an EU Carnet to bring i...   Mar 7 2023, 07:52 PM
roundtwo   @ClayPerrine @bossboy320 Good point about emissio...   Mar 8 2023, 01:21 AM
930cabman   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 8 2023, 06:02 AM
peteinjp   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 8 2023, 03:47 AM
ClayPerrine   MFI has altitude adjustment... Just sayin. Pet...   Mar 8 2023, 06:30 AM
JmuRiz   :idea:   Mar 8 2023, 04:51 PM
Eric_Shea   Not yet Pete. Bob's was the early Sport air f...   Mar 8 2023, 07:09 PM
horizontally-opposed   Not yet Pete. Bob's was the early Sport air ...   Mar 9 2023, 03:49 PM
Superhawk996   :hijacked: OP asks A or B Answer - you need ...   Mar 8 2023, 07:14 PM
Steve   :hijacked: :evilgrin: :deadhorse: Tons of in...   Mar 8 2023, 07:17 PM
Eric_Shea   Ooooooooooooooops! Thread police! :lol: ...   Mar 8 2023, 07:33 PM
Superhawk996   Thread police here :cop: It’s all in good fun...   Mar 9 2023, 04:18 PM
tygaboy   In case anyone cares: my main gripe with Holley EC...   Mar 9 2023, 04:35 PM
Superhawk996   In case anyone cares: my main gripe with Holley E...   Mar 9 2023, 06:57 PM
tygaboy   In case anyone cares: my main gripe with Holley ...   Mar 9 2023, 07:14 PM
Eric_Shea   True dat. This is one of the reasons our builds...   Mar 13 2023, 01:47 PM
- Lo-Fi Version Time is now: 12th March 2026 - 04:20 PM
