> 25Amp Relay Board Fuse, Relay Board Amp fuse
tbone1819
post Mar 9 2023, 11:40 AM
Hey all,
Just wondering if any of you have run into the 25A relay board fuse blowing. I've had the fuse go twice after taking the car on a good run and after the car has completly cooled down. What ground could be bad? Where should I start?
914Sixer
post Mar 9 2023, 06:41 PM
Lever has green wire (12v) connected at the base. Raising the lever completes the circuit to turn on blower fan in engine compartment. Check relay board bottom for corrosion, check fuel pump relay.
- Lo-Fi Version Time is now: 7th December 2025 - 06:42 AM
