Magnetic fired ignition, Anyone running it on a 4? |
-JR- |
Jan 20 2005, 01:27 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I've been putting together my new 2+ litre engine and have been looking into flywheel fired magnetic ignition. The crank fired ignition won't work too well I guess since the front of the engine is buried in air ducting.
I am contemplating installing two of these into my flywheel to run a MSD 6AL system. There is a nice inspection hole on one half of the case that would be perfect to mount a pickup in. Anyone tried this beofre and if so any pics or suggestions? Thanks! -JR- |
TimT |
Jan 20 2005, 02:11 AM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
You could put the 4 magnets (4 magnets is you need a "home" signal 3 if you just need the firing interval) in the flywheel, and then use any number of pickups for the trigger.
The 3.2 and later /6's use a toothed wheel on the flywheel for the ignition/timing signal. No reason you cant use magnets in this case |
Lo-Fi Version | Time is now: 1st June 2024 - 01:18 PM |
