| jim_hoyland |
Mar 11 2023, 03:57 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,034 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
Did the 6s come with the rain tray ?
| rhodyguy |
Mar 12 2023, 02:58 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Good pictures. I see the Y, the case vapor draw off is pre air filter? How difficult is replacing the filter element(s)?
| fixer34 |
Mar 12 2023, 07:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,399 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Good pictures. I see the Y, the case vapor draw off is pre air filter? How difficult is replacing the filter element(s)? Piece of cake. Unsnap the hold down clips on the carb shrouds, lift slightly so you can reach in and pull off the breather hose coming from the oil tank and take it out. Loosen 2 wing nuts holding the snorkel, twist slightly and pull off. Filter right there. Breather is actually post air filter. There is also a small drain hose on the bottom of the filter housing that vents to the outside (you can just barely see it to the right of the Y). Rain tray? I don't think there is even an inch from the top of the housing to the engine lid. Anything you try to put on there is going to cut airflow to the engine and cause it to overheat. The six draws a lot more air than the 4. |
jim_hoyland 914-6’s Mar 11 2023, 03:57 PM
bossboy302 No, they did not. Wouldn't clear air filter h... Mar 11 2023, 04:01 PM
mepstein 914-6 used an air filter housing (similar to 911â€... Mar 11 2023, 04:05 PM
fixer34
914-6 used an air filter housing (similar to 911â... Mar 11 2023, 05:10 PM
bossboy302
914-6 used an air filter housing (similar to 911... Mar 11 2023, 05:28 PM
fixer34
[quote name='fixer34' post='3064286' date='Mar 11... Mar 12 2023, 02:50 PM
RARE 6
Good pictures. I see the Y, the case vapor draw o... Mar 12 2023, 03:58 PM
Root_Werks I would love a low profile rain tray for a six. My... Mar 12 2023, 06:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 11:03 AM |
