| shag |
Mar 13 2023, 01:19 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 18-January 14 From: mount wolf pa Member No.: 16,901 Region Association: North East States
Help, my ignition switch will not turn. I can install and remove key. After I jiggled the key the buzzer sounded because the door was open but I still could not turn the key. I would like to keep the original key and just repair the switch if I can but how do I repair this?
| GregAmy |
Mar 13 2023, 04:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,648 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
This is NOT a "dis" to the OP...seriously, it's not.
This is an old-guy rant (with cane pointed at clouds) about how our steering shafts have always (well, since around '69/'70) been locked with a pin/shaft extending from the manual lock cylinder into the steering shaft so that the car could not be stolen if it was hot-wired, because the perp could not turn the steering lock. So you had to relieve that friction from the shaft so that you could turn the pin with the key. I mean, I thought EVERYONE* knew this...! To the OP: you're driving a manual transmission car. I salute you. Go forth and multiply. I'm going back to my Geritol (you can look it up). - GA *Well, GenX and beyond... |
shag ignition switch will not turn Mar 13 2023, 01:19 PM
Robarabian Maybe you have a stuck wafer in the lock...
You c... Mar 13 2023, 01:30 PM
shag You think If I just put a bunch of dry lubricant o... Mar 13 2023, 01:36 PM
mihai914 Just wait a little, there is a member here who reb... Mar 13 2023, 01:41 PM
shag Ok, I just returned from the garage and I don... Mar 13 2023, 01:47 PM
r_towle Have you wiggled the steering wheel to take the pr... Mar 13 2023, 02:02 PM
euro911
Have you wiggled the steering wheel to take the p... Mar 13 2023, 02:39 PM
shag r towle, That was it!!! I know I had... Mar 13 2023, 02:33 PM
shag Mihai, I would like to ask the individual you are... Mar 13 2023, 03:19 PM
StarBear
Mihai, I would like to ask the individual you ar... Mar 13 2023, 03:42 PM
mihai914
Mihai, I would like to ask the individual you ar... Mar 14 2023, 06:35 AM
r_towle If you take one apart you will see the key cylinde... Mar 13 2023, 04:15 PM
Osnabruck914 Once again r_towle has the answer. He has given g... Mar 13 2023, 05:48 PM
shag I would like to thank you all for your comments an... Mar 13 2023, 07:52 PM
technicalninja A bunch of new cars no longer have the steering lo... Mar 13 2023, 08:11 PM
shag Hello Mihai, Thanks for the good reading material... Mar 14 2023, 03:21 PM
TheCabinetmaker Glad you got it sorted! Rich is usually on the... Mar 14 2023, 06:57 PM
shag Thanks to all and for not making me feel like the ... Mar 15 2023, 09:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 12:23 PM |
