Monday, 11 August 2025 |
roundtwo |
Member ![]() ![]() Group: Members Posts: 325 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California ![]() ![]() |
OK, so I’ve scoured previous post about this topic and I’m now at this point.
-cleaning up some previous owner work - VDO fuel gauge part number V301030. Rated 0 to 90 ohms. - New stock sending unit putting out 36 ohms now as gas tank about 1/2 full. - all wires continuity tested and I’m sure i all hooked up correctly. Yes-grounds all checked. Problem- gauge reads full. -assumption the pin configuration on the sending unit plug is correct- see pic Fix? - install VDO gauge v301020. Range 10-73 ohms - Will this gauge work close enough with the stock sender? Or…. Do I need to replace the stock sending unit to match the gauge ohm range exactly? Thanks for the help ![]() ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,753 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Believe the correct VDO gauge is 301 020 which isn't made. I found a NOS gauge a while back.
Went through this a couple of years ago: http://www.914world.com/bbs2/index.php?sho...=346657&hl= Reading through my old thread, I found a VDO 301-220 which works well. Run the 914 fairly low on fuel and it reads it. Fill the tank and it reads it. So pretty darn close to matching up with the sending unit. |
roundtwo |
Believe the correct VDO gauge is 301 020 which isn't made. I found a NOS gauge a while back. Went through this a couple of years ago: http://www.914world.com/bbs2/index.php?sho...=346657&hl= Reading through my old thread, I found a VDO 301-220 which works well. Run the 914 fairly low on fuel and it reads it. Fill the tank and it reads it. So pretty darn close to matching up with the sending unit. @Root_Werks Thanks Roots. Good to have two person confirmation. Noticed the 301-220 also for Vdub. Pretty darn close is more than close enough for me. Todd |
Lo-Fi Version | Time is now: 11th August 2025 - 01:31 PM |
