> The two bleeders
emerygt350
post Mar 17 2023, 07:38 PM
I just popped on my newly remastered rear brake calipers from PMB and was wondering if there was a point to the lower bleeder? I only ever bothered with the top bleeder before but now that it's bone dry I was wondering if that might be why the second bleeder exists? I will be bleeding the brakes tomorrow morning.
davep
post Mar 18 2023, 07:21 AM
914 Historian
Dual bleed nipples of the 914 rear have nothing to do with handedness, the parking brake lever defines that.
However, I have found that when doing an annual fluid bleed it is often better to open both bleed nipples to fully drain the calipers before refilling. Forty years ago I had to start rebuilding the calipers to keep them fully functional; there was no PMB to send calipers to and there were no (!) parts available in any case. Taking the pistons out was a real eye opener since the outer pistons were always filled with more crap than the inners. The reason for this is simple. The fluid inlet is on the inner side of the caliper as are the bleed nipples. When you do a quick flush and bleed the fluid enters the inlet and heads straight for the open nipple. This does not flush the fluid inside the pistons, particularly the 914 rears with the adjuster mechanism inside, and it certainly does not do much of a job in circulating to the outer half of the caliper. The result is that old fluid is retained inside the pistons and most of the outer caliper half with a quick flush and bleed. Hence my method was to drain the calipers first, then do a complete refill and bleed. Every few years I would disassemble the calipers to thoroughly clean inside to keep them operating efficiently.
emerygt350   The two bleeders   Mar 17 2023, 07:38 PM
StarBear   Good question. Curious, too. Dual bleeders on late...   Mar 17 2023, 08:02 PM
Superhawk996   Dual bleeders facilitate the part being used on ei...   Mar 17 2023, 10:32 PM
iankarr   On one car I had a harder time than usual getting ...   Mar 17 2023, 11:59 PM
davep   Dual bleed nipples of the 914 rear have nothing to...   Mar 18 2023, 07:21 AM
930cabman   Dual bleed nipples of the 914 rear have nothing t...   Mar 18 2023, 08:11 AM
Superhawk996   Dual bleed nipples of the 914 rear have nothing t...   Mar 18 2023, 10:49 AM
davep   The casting is not handed until the machining ope...   Mar 18 2023, 07:10 PM
technicalninja   Dual bleed nipples of the 914 rear have nothing t...   Mar 18 2023, 07:57 AM
technicalninja   Disagree. You have to look at this from a manufa...   Mar 18 2023, 11:25 AM
emerygt350   Shoot, wish I had read Dave's comment earlier....   Mar 18 2023, 01:55 PM
Superhawk996   I think the one thing we can agree on is that thes...   Mar 18 2023, 08:04 PM
Van914   Ferrari 308 uses the same rear calipers. I think t...   Mar 19 2023, 04:15 AM
Superhawk996   Ferrari 308 uses the same rear calipers. I think ...   Mar 19 2023, 06:52 AM
davep   Ferrari 308 uses the same rear calipers. I think ...   Mar 19 2023, 08:04 AM
Krieger   Here are my 308 calipers. I had a machinist add th...   Mar 19 2023, 11:24 AM
Superhawk996   Here are my 308 calipers. I had a machinist add t...   Mar 19 2023, 12:11 PM
Krieger   Here are my 308 calipers. I had a machinist add ...   Mar 19 2023, 06:41 PM
zoomCat   Here are my 308 calipers. I had a machinist add t...   Mar 19 2023, 12:56 PM
Superhawk996   Nope - I’m wrong on a casting common to all thre...   Mar 19 2023, 12:34 PM
PatMc   Nope - I’m wrong on a casting common to all thr...   Mar 20 2023, 08:48 AM
Krieger   And some casting variations with mine. @Superhawk...   Mar 19 2023, 06:58 PM
Superhawk996   Thank you for the alternate views. Nice score fo...   Mar 19 2023, 09:43 PM
- Lo-Fi Version Time is now: 24th September 2026 - 07:49 AM
