| emerygt350 |
Mar 17 2023, 07:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,752 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I just popped on my newly remastered rear brake calipers from PMB and was wondering if there was a point to the lower bleeder? I only ever bothered with the top bleeder before but now that it's bone dry I was wondering if that might be why the second bleeder exists? I will be bleeding the brakes tomorrow morning.
| davep |
Mar 18 2023, 07:21 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,376 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Dual bleed nipples of the 914 rear have nothing to do with handedness, the parking brake lever defines that.
However, I have found that when doing an annual fluid bleed it is often better to open both bleed nipples to fully drain the calipers before refilling. Forty years ago I had to start rebuilding the calipers to keep them fully functional; there was no PMB to send calipers to and there were no (!) parts available in any case. Taking the pistons out was a real eye opener since the outer pistons were always filled with more crap than the inners. The reason for this is simple. The fluid inlet is on the inner side of the caliper as are the bleed nipples. When you do a quick flush and bleed the fluid enters the inlet and heads straight for the open nipple. This does not flush the fluid inside the pistons, particularly the 914 rears with the adjuster mechanism inside, and it certainly does not do much of a job in circulating to the outer half of the caliper. The result is that old fluid is retained inside the pistons and most of the outer caliper half with a quick flush and bleed. Hence my method was to drain the calipers first, then do a complete refill and bleed. Every few years I would disassemble the calipers to thoroughly clean inside to keep them operating efficiently. |
| 930cabman |
Mar 18 2023, 08:11 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,833 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Dual bleed nipples of the 914 rear have nothing to do with handedness, the parking brake lever defines that. However, I have found that when doing an annual fluid bleed it is often better to open both bleed nipples to fully drain the calipers before refilling. Forty years ago I had to start rebuilding the calipers to keep them fully functional; there was no PMB to send calipers to and there were no (!) parts available in any case. Taking the pistons out was a real eye opener since the outer pistons were always filled with more crap than the inners. The reason for this is simple. The fluid inlet is on the inner side of the caliper as are the bleed nipples. When you do a quick flush and bleed the fluid enters the inlet and heads straight for the open nipple. This does not flush the fluid inside the pistons, particularly the 914 rears with the adjuster mechanism inside, and it certainly does not do much of a job in circulating to the outer half of the caliper. The result is that old fluid is retained inside the pistons and most of the outer caliper half with a quick flush and bleed. Hence my method was to drain the calipers first, then do a complete refill and bleed. Every few years I would disassemble the calipers to thoroughly clean inside to keep them operating efficiently. Thank you for clarifying this, the dual bleeders have been a mystery for me and I am sure many others. |
emerygt350 The two bleeders Mar 17 2023, 07:38 PM
StarBear Good question. Curious, too. Dual bleeders on late... Mar 17 2023, 08:02 PM
Superhawk996 Dual bleeders facilitate the part being used on ei... Mar 17 2023, 10:32 PM
iankarr On one car I had a harder time than usual getting ... Mar 17 2023, 11:59 PM
Superhawk996
Dual bleed nipples of the 914 rear have nothing t... Mar 18 2023, 10:49 AM
davep
The casting is not handed until the machining ope... Mar 18 2023, 07:10 PM
technicalninja
Dual bleed nipples of the 914 rear have nothing t... Mar 18 2023, 07:57 AM
technicalninja
Disagree. You have to look at this from a manufa... Mar 18 2023, 11:25 AM
emerygt350 Shoot, wish I had read Dave's comment earlier.... Mar 18 2023, 01:55 PM
Superhawk996 I think the one thing we can agree on is that thes... Mar 18 2023, 08:04 PM
Van914 Ferrari 308 uses the same rear calipers. I think t... Mar 19 2023, 04:15 AM
Superhawk996
Ferrari 308 uses the same rear calipers. I think ... Mar 19 2023, 06:52 AM
davep
Ferrari 308 uses the same rear calipers. I think ... Mar 19 2023, 08:04 AM
Krieger Here are my 308 calipers. I had a machinist add th... Mar 19 2023, 11:24 AM
Superhawk996
Here are my 308 calipers. I had a machinist add t... Mar 19 2023, 12:11 PM
Krieger
Here are my 308 calipers. I had a machinist add ... Mar 19 2023, 06:41 PM
zoomCat
Here are my 308 calipers. I had a machinist add t... Mar 19 2023, 12:56 PM
Superhawk996 Nope - I’m wrong on a casting common to all thre... Mar 19 2023, 12:34 PM
PatMc
Nope - I’m wrong on a casting common to all thr... Mar 20 2023, 08:48 AM
Krieger And some casting variations with mine. @Superhawk... Mar 19 2023, 06:58 PM
Superhawk996 Thank you for the alternate views.
Nice score fo... Mar 19 2023, 09:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th September 2026 - 07:49 AM |
