> need some help with floor plan fix, peeling the coating, POR15, etc
914 RZ-1
post Mar 17 2023, 08:39 PM
Porsche Padawan
The M/C leaked all over the floor plan. There's some rust as well. Before I put back everything I thought I would clean it all up.
1. What is the best way to get all the coating off the floor pan? It looks like some sort of asphalt/tar paper. It seems to be peeling off okay with a putty knife. I'm guessing I use some sort of solvent to get the remaining gunk off? Heat gun?
2. I have a kit that has cleaner/degreaser, metal prep and POR15. I also want to reseal around whatever that is (plug?) in the middle with some seam sealer. What order is this all applied?
-cleaner
-prep
-POR15
-seam sealer
OR
-cleaner
-prep
-seam sealer
-POR15
Or some other order?
3. I was going to leave the POR15 as the final coat, but do I need to paint over it? The car is silver/gray, the POR15 is gloss black. It's under the carpet and under the floor mat, so it will not show. I'm more concerned with keeping the rust at bay.
4. Where should I stop the painting? At a seal? At one of the changes in contour of the floor pan? Please note that the car was in an accident many years ago (before my ownership) and was repaired, but the floor pan is still a little uneven. My concern is that the paint will wick under the tar paper, but is that even an issue?
Here's a photo, since I know we all like pictures. There is a pile of tar paper on the left:
Thanks!
-Jeff
technicalninja
post Mar 18 2023, 12:23 PM
QUOTE(Superhawk996 @ Mar 18 2023, 01:02 PM) *
Chill dude - it was a joke complete with picture of American philosophy of if a little is good more is better.
You have an interesting way of joking...
It came off as:
"Please don’t encourage the use of fiberglass to fix floor pans."
I don't like using bondo-fiberglass in bodywork.
I prefer lead...
I would never suggest fiberglass for any metal work.
When I first saw others using POR15 to fix small holes I was a dis-believer.
Until I tried it myself...
It is the ONLY small hole patching material I've ever seen actually work in a permanent fashion.
I thought the fiberglass velum would print through it and you could see it.
Nope, not at all. The POR15 is thick enough and the fiberglass is thin enough that it just blends in.
It can work for small pinholes in a basically good panel.
It cannot fix major destruction.
914 RZ-1   need some help with floor plan fix   Mar 17 2023, 08:39 PM
bkrantz   How much rust? And how far do you want to go? If...   Mar 17 2023, 09:59 PM
ogdougy   If you want to remove it with that "deep free...   Mar 17 2023, 10:25 PM
technicalninja   I'd do it the first way. The POR 15 needs to ...   Mar 18 2023, 09:59 AM
Superhawk996   POR15 sells fiberglass velum cloth, This is fibe...   Mar 18 2023, 11:05 AM
technicalninja   Please don’t encourage the use of fiberglass...   Mar 18 2023, 11:42 AM
Superhawk996   Please don’t encourage the use of fiberglas...   Mar 18 2023, 12:02 PM
technicalninja   Chill dude - it was a joke complete with picture...   Mar 18 2023, 12:23 PM
914 RZ-1   Thanks for the help! I was able to find more...   Mar 19 2023, 11:27 AM
Superhawk996   In my opinion, you’re over thinking it. It’s...   Mar 19 2023, 11:47 AM
914 RZ-1   In my opinion, you’re over thinking it. It’...   Mar 19 2023, 03:53 PM
Superhawk996   Good job trying to do this well. It’s always a ...   Mar 19 2023, 11:50 AM
914werke   You have an interesting way of joking... It came ...   Mar 19 2023, 12:05 PM
technicalninja   The tie-coat primer that POR15 sells is grey. At ...   Mar 19 2023, 12:18 PM
914 RZ-1   The tie-coat primer that POR15 sells is grey. At...   Mar 19 2023, 01:31 PM
technicalninja   But it does appear you are promoting the use of P...   Mar 19 2023, 12:36 PM
SirAndy   Those who have failed with POR15 didn't use it...   Mar 19 2023, 12:52 PM
Superhawk996   I'm not even sure you can do lead work any lo...   Mar 19 2023, 01:02 PM
technicalninja   I'm all ears for other's opinions. Please ...   Mar 19 2023, 12:57 PM
technicalninja   POR15 has an expensive metal prep called Metal-Rea...   Mar 19 2023, 01:18 PM
Superhawk996   POR15 has an expensive metal prep called Metal-Re...   Mar 19 2023, 01:27 PM
rjames   POR15 gets a bad rap. I suppose YMMV could vary, b...   Mar 19 2023, 04:11 PM
- Lo-Fi Version Time is now: 2nd October 2026 - 11:45 AM
