> Aftermarket FI options for Type 4 motors 2056 or larger, Who here has gone this route and is it worth it? What options do we have?
DRPHIL914
post Feb 6 2023, 09:05 AM
Dr. Phil
i started looking into this 2 years ago when i was planning my rebuild motor after the drpped valve seat on the OEM motor.
I ended up building a nice 2056 with increased compression, brand new heads, counter balanced crank and of course the cam is performance minded as well.
to start i installed the d-jet and later last year i added a 50mm bored out stock throttle body from Tangerine/Chris Foley. Yes this helped a great deal, but we are still limited due to the d-jet and the MPS. So there are a few people out there that make ITB( independant throttle body) that could be used.
One is Jenvey, and i see that PMB is carrying those. It looks ike they are mated to what ever IDF intake manifold you choose. there are 40, 45, 48 options. mated with 350cc injectors.
I am wondering other than the CB performance stuff that has been available for a while, others have come to the table, who here has played around with this ? over the years ive read a lot on others using the megasquirt and micro etc and it seemd they were very difficult to tune and set up with lots of problems, trial and error.
I am looking for advice on what to stay away from and what are the pitfalls and mistakes we can avoid before jumping into this.
Look forward to some input, thanks!!
Phil
jd74914
post Mar 25 2023, 05:04 AM
Its alive
(IMG:style_emoticons/default/agree.gif) That stuff really was ahead of it’s time.
That’s before my time-I would have been in elementary school or middle school when people were really playing with socketed EEPROM. (IMG:style_emoticons/default/laugh.gif) First I’d seen if that stuff was when a buddy bought a modded CRX in high school with a newer motor and S300.
GregAmy
post Mar 25 2023, 05:44 AM
QUOTE(jd74914 @ Mar 25 2023, 06:04 AM) *
That’s before my time-I would have been in elementary school or middle school...
All right young-uns, let me tell you how we used to connect to GENie with a device that made enough noise to get your momma's attention as to why you weren't in bed already... (IMG:style_emoticons/default/beerchug.gif)
Definitely "old school". D-Jet (and L-Jet) were so far ahead of their time that full ECU control was, really, still in the future (many don't realize that the mighty 956s Motronic engine management system was a derivative). This came for the fore in the early- to mid-90s with OBD, some systems using pressure (Druck for D-Jet) some using air flow meter (Luft for L-Jet).
Those ECU-controlled cars finally became affordable used cars in the late 90s, and that's when ECU hacking took off. Socketed EEPROMs were the only way to go at the time. You'd find someone to solder in a socket on your board, buy multiple EEPRMs, connect an EEPROM to your computer using an RS232 device, burn the EEPROM. Insert, dyno test. Look at the results, grab another EEPROM to burn with the new tune, swap them, dyno test. Then do it all over again. Tedious.
My first experience with it was in racing with the SR20-equpped Nissan B13s. We weren't even using wideband feedback or data acquisition yet so we'd grab feedback from the driver on where the O2 was down the longest straight and *maybe* take the time to retune the EEPROM, always leaving the weekend's baseline EEPROM off to the side just in case we mucked it up. Even the software was primitive and fidgety to learn. It was right about that time, circa 2005 or so, that guys like CalumSult that tried USB connection and companies like DIYAutotune started offering replacement ECUs (their PnP series) that had USB ports for tuning. Hondata S300. And then eventually wideband feedback, and some times realtime tuning! Life was good.
So I'd really like to meet the guy or gal that did that P06 install into the 914. It was sharp engineering. And I like the way they were thinking! - GA
DRPHIL914   Aftermarket FI options for Type 4 motors 2056 or larger   Feb 6 2023, 09:05 AM
DRPHIL914   forgot to add this link, its the PMB page listing ...   Feb 6 2023, 09:06 AM
GregAmy   We have several good discussion topics already goi...   Feb 6 2023, 09:30 AM
DRPHIL914   We have several good discussion topics already go...   Feb 6 2023, 09:45 AM
scott_in_nh   We have several good discussion topics already go...   Feb 8 2023, 04:37 PM
GregAmy   That was a good read - thanks for taking the time ...   Feb 8 2023, 04:57 PM
scott_in_nh   That was a good read - thanks for taking the time...   Feb 8 2023, 05:25 PM
GregAmy   Well, thinking outside the box, there's no rea...   Feb 6 2023, 09:53 AM
Geezer914   2056, 9:1 CR. 9550 cam, 50mm vanagon throttle bod...   Feb 6 2023, 10:10 AM
rgolia   I am looking hard at this as I am getting tired of...   Feb 6 2023, 01:48 PM
mihai914   I am looking hard at this as I am getting tired o...   Feb 7 2023, 08:04 AM
914Sixer   Currently sold out but more on the way.   Feb 6 2023, 02:05 PM
DRPHIL914   ok wow lots of great comments here i just got caug...   Feb 7 2023, 10:57 AM
Superhawk996   seems keeping direct injection is best Totally...   Feb 7 2023, 12:30 PM
GregAmy   You can do that. I just decided to use the stock r...   Feb 6 2023, 04:11 PM
billh1963   Probably a stupid question but are Holley sniper a...   Feb 6 2023, 04:18 PM
GregAmy   Probably a stupid question but are Holley sniper ...   Feb 6 2023, 04:35 PM
mihai914   Probably a stupid question but are Holley sniper ...   Feb 7 2023, 07:46 AM
Superhawk996   Probably a stupid question but are Holley sniper...   Feb 7 2023, 08:58 AM
914werke   Ive talked to those guys, it seems the real value ...   Feb 6 2023, 06:35 PM
JamesM   Look forward to some input, thanks!! Phi...   Feb 6 2023, 07:19 PM
MSGGrunt   I have converted my 1969 TR6 with twin SU side dra...   Feb 6 2023, 07:24 PM
emerygt350   If it were me, I would see if the stock FI will wo...   Feb 7 2023, 08:33 AM
emerygt350   I work with early tbi (CFI in the ford world). It...   Feb 7 2023, 10:35 AM
Superhawk996   I work with early tbi (CFI in the ford world). I...   Feb 7 2023, 12:22 PM
Jack Standz   I work with early tbi (CFI in the ford world). I...   Feb 7 2023, 01:03 PM
Aerostatwv   I thought there is a difference with injectors. Th...   Feb 7 2023, 11:02 AM
Superhawk996   I thought there is a difference with injectors. T...   Feb 7 2023, 12:36 PM
Superhawk996   What is with with the love of TBI? Sure dual TBI...   Feb 7 2023, 01:32 PM
mihai914   What is with with the love of TBI? Sure dual TB...   Feb 7 2023, 02:46 PM
JamesM   Sniper EFI, FiTEch and all other similar product...   Feb 7 2023, 03:19 PM
Superhawk996   Using the term "Self Tune" is along the...   Feb 7 2023, 03:38 PM
mihai914   [quote name='JamesM' post='3056265' date='Feb 7 2...   Feb 7 2023, 04:04 PM
emerygt350   What is with with the love of TBI? Sure dual T...   Feb 7 2023, 03:46 PM
Jack Standz   What is with with the love of TBI? Sure dual TB...   Feb 7 2023, 03:38 PM
rhodyguy   A local member had a big T4 and I think he used th...   Feb 7 2023, 01:43 PM
rbzymek   I worked at Ford in the engine controls department...   Feb 7 2023, 02:01 PM
Superhawk996   Fair points but let me address throttle by wire. ...   Feb 7 2023, 03:56 PM
GregAmy   The safety implications of moving to throttle by ...   Feb 7 2023, 04:14 PM
Superhawk996   :beer3: The initial Audi unintended acceleration ...   Feb 7 2023, 04:38 PM
Superhawk996   The Toyota unintended acceleration issue was a res...   Feb 7 2023, 04:41 PM
mihai914   Food for thought: https://www.holley.com/blog/pos...   Feb 7 2023, 05:11 PM
Superhawk996   Food for thought: https://www.holley.com/blog/po...   Feb 7 2023, 05:21 PM
Jack Standz   Well, I don't know how Edelbrock got it to wor...   Feb 7 2023, 06:45 PM
Superhawk996   Well, I don't know how Edelbrock got it to wo...   Feb 7 2023, 07:29 PM
emerygt350   No fun car of mine is in spec. And they both have...   Feb 7 2023, 07:30 PM
Superhawk996   Was reading the Holly quick start guide. This gui...   Feb 7 2023, 07:53 PM
bkrantz   I have the Dub Shop kit on my 2056. As delivered ...   Feb 7 2023, 09:12 PM
DRPHIL914   I have the Dub Shop kit on my 2056. As delivered...   Feb 8 2023, 07:51 AM
rgolia   I have the Dub Shop kit on my 2056. As delivere...   Feb 8 2023, 11:52 AM
DRPHIL914   [quote name='bkrantz' post='3056369' date='Feb 7...   Feb 8 2023, 12:57 PM
mihai914   I have the Dub Shop kit on my 2056. As delivere...   Feb 8 2023, 01:20 PM
DRPHIL914   [quote name='DRPHIL914' post='3056437' date='Feb ...   Feb 8 2023, 01:36 PM
rgolia   I have the Dub Shop kit on my 2056. As delivered...   Feb 8 2023, 11:53 AM
bkrantz   I have the Dub Shop kit on my 2056. As delivere...   Feb 8 2023, 09:09 PM
rgolia   [quote name='bkrantz' post='3056369' date='Feb 7...   Feb 9 2023, 08:40 AM
bkrantz   [quote name='bkrantz' post='3056613' date='Feb 8 ...   Feb 9 2023, 09:03 PM
bkrantz   [quote name='bkrantz' post='3056613' date='Feb 8 ...   Mar 24 2023, 08:54 PM
emerygt350   superhawk, that is awesome. However, I have had a...   Feb 8 2023, 07:24 AM
GeorgeKopf   Has anybody looked at Simple Digital Systems for a...   Feb 8 2023, 02:45 PM
mihai914   Ok, to keep the ball rolling, can we also talk abo...   Feb 8 2023, 07:33 PM
mepstein   Installing FI is never cheap. People always undere...   Feb 8 2023, 08:28 PM
r_towle   Last time I looked at this CBPerformance sold comp...   Feb 8 2023, 10:54 PM
Superhawk996   :agree: Like rgolia, I’ve leaned toward DubSho...   Feb 9 2023, 08:48 AM
mihai914   I found this thread specifically about the Dub Sho...   Feb 9 2023, 10:45 AM
GregAmy   Just a quick bump to report a new "find...   Mar 24 2023, 01:57 PM
jd74914   That’s wild. Had to have been done in the late 9...   Mar 24 2023, 07:55 PM
GregAmy   That’s wild. Had to have been done in the late ...   Mar 24 2023, 08:55 PM
jd74914   :agree: That stuff really was ahead of it’s time...   Mar 25 2023, 05:04 AM
GregAmy   That’s before my time-I would have been in elem...   Mar 25 2023, 05:44 AM
r_towle   Back about 15,years ago, I tuned a 2.4 liter to 15...   Mar 25 2023, 09:16 AM
targa72e   Not quite 914 FI related but Porsche related. I re...   Mar 25 2023, 10:24 PM
VaccaRabite   One of the things I'd be wary of with the Dub ...   Mar 27 2023, 06:23 AM
GregAmy   One of the things I'd be wary of with the Dub...   Mar 27 2023, 11:19 AM
GregAmy   [quote name='VaccaRabite' post='3067937' date='Ma...   Mar 27 2023, 05:28 PM
rick 918-S   [quote name='VaccaRabite' post='3067937' date='M...   Mar 28 2023, 01:14 AM
r_towle   [quote name='GregAmy' post='3068081' date='Mar 27...   Apr 9 2024, 02:43 PM
VaccaRabite   [quote name='VaccaRabite' post='3067937' date='M...   Mar 28 2023, 05:23 AM
GregAmy   Interesting. I'm assuming the timing retard ...   Mar 28 2023, 05:41 AM
Geezer914   Search for a used Ljet system. You can adjust the...   Mar 27 2023, 09:31 AM
ClayPerrine   Search for a used Ljet system. You can adjust th...   Mar 27 2023, 10:57 AM
falcor75   Search for a used Ljet system. You can adjust t...   Mar 27 2023, 12:30 PM
jd74914   Controlling idle with spark timing is really the w...   Mar 27 2023, 11:52 PM
jd74914   In tank is the way to go if you can make it work. ...   Mar 28 2023, 01:31 AM
ClayPerrine   In tank is the way to go if you can make it work....   Mar 28 2023, 05:04 AM
Gatornapper   Impecable timing as to this thread - almost as if ...   Apr 8 2024, 06:55 PM
DRPHIL914   Impecable timing as to this thread - almost as if...   Apr 9 2024, 10:40 AM
DRPHIL914   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 9 2024, 10:41 AM
VaccaRabite   @[url=http://www.914world.com/bbs2/index.php?show...   Apr 9 2024, 07:13 PM
mepstein   There are places to send a throttle body out, get ...   Apr 9 2024, 04:35 PM
flxzcat   There are places to send a throttle body out, get...   Nov 6 2024, 04:18 PM
Gatornapper   Thanks Ben - did not know that. The 50mm (from 45...   Apr 9 2024, 07:29 PM
flxzcat   Regarding previous talk of Weber like FI throttle ...   Nov 6 2024, 04:32 PM
914werke   RE: Aftermarket FI options for Type 4 motors 2056 or larger   Nov 6 2024, 05:55 PM
Craigers17   I watched this video from Jake Raby over the weeke...   Nov 7 2024, 03:55 PM
JamesM   I watched this video from Jake Raby over the week...   Nov 8 2024, 01:44 AM
914werke   It seems that he and Mario from the Dub Shop hav...   Nov 7 2024, 06:16 PM
Craigers17   It seems that he and Mario from the Dub Shop ha...   Nov 7 2024, 08:28 PM
Mikey914   Well, I'm currently working on a version of a ...   Nov 10 2024, 03:17 AM
- Lo-Fi Version Time is now: 1st November 2026 - 04:38 PM
