> Project 914n6 -> the infamous Nissan V6 swap, new motor buildup
Chris914n6
post Jul 26 2022, 03:04 AM
Jackstands are my life.
Logic, according to my brain...
In 2000 I installed a Nissan VQ30, 3.0L from a 97 Maxima. 190hp 205tq and it was great. Then things happened (rusted battery tray). Then it sat for a decade (recession). The engine now overheats the cooling system like a bad head gasket. Likely from aluminum erosion from sitting too long (other signs). Fixing that requires complete disassembly down to a short block.
Soooo....
I decided to move up to a VQ35, 03 Maxima 3.5L +80hp!!! (that's 42% more)
Here's the rub. To get the VQ30 to fit I moved everything forward 1.5". Renegade sbc trans blocks, shortened shift rod, small hole in the truck. To fit the VQ35 as-is I would need to move it back, likely to stock location, to clear the variable cam timing stuff. That means a new cross mount, new shift rod, redo exhaust, plus new harness and ms3pro ecu ($$$$).
Turns out the gearheads at Maxima.org like to upgrade too. They created a VQ30/35 hybrid. It's a VQ35 engine with VQ30 ecu, harness, timing components and accessories. I lose the variable cam timing but I get to reuse all my custom swap bits, which saves a bunch of time I don't have before RRC22. But it requires some new custom parts.
If one or more of our great fabricators has time and tools I'd love to toss email money your way. @mueller @tygaboy @mb911
First is the Throttle Body adapter. Replacing the factory e-gas with cable. I currenly have this partially drawn in CorelDraw and design is not absolute (still searching hardware). 96mm x 99mm. TB (red) bolts to piece_1 (blue) which bolts to piece_2 (green) which bolts to IM (yellow).
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826257.1.jpg)
Second is cam gear adapters/spacers in steel. I need 2 @ 178* and 2 @ 180*. 4 total cuz 4 cams of fury. 6mm dowel pins look to be readily available.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.2.jpg)
Third is a pair of aluminum block-off plates for the VVT cam adjusters. 1.5" x 3.5" Also drawn in CorelDraw, which can be exported as .ai or .dxf. Actually I might make these by hand.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.3.jpg)
Gratuitous PartsFinder pic
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.4.jpg)
tygaboy
post Apr 10 2023, 09:09 AM
To @clayperrine Clay's question: Chris is handy and clearly likes to fab stuff so more of a DIY may appeal to him. Plus the aforementioned cost savings.
Plus, I suspect Chris is a charter member of the "mine is different/special" club! (IMG:style_emoticons/default/aktion035.gif)
That said, I've been noodling on re-powering my LS car with a Nissan V6 and, if I understand it correctly, Kennedy Engineering could supply a complete adaptor kit to the Boxster trans, if he wanted to go that way.
Chris914n6   Project 914n6 -> the infamous Nissan V6 swap   Jul 26 2022, 03:04 AM
tygaboy   I may be able to assist with the block off plates....   Jul 26 2022, 07:49 AM
Mueller   Hi Chris, Remind me late next week if not in a h...   Jul 26 2022, 07:59 AM
Chris914n6   Think you'll do a VR30DDTT from a new Z or In...   Jul 30 2022, 02:49 PM
Chris914n6   Made it to the Gaudin Porsche Bumblebee reveal. Th...   Jul 30 2022, 02:58 PM
Chris914n6   Let's file this under things I don't want ...   Aug 9 2022, 03:59 PM
Mueller   Looks easier than an Audi. Are upgraded guides ava...   Aug 9 2022, 04:36 PM
Chris914n6   The factory fix is updated guides and chain. The c...   Aug 10 2022, 07:57 PM
Chris914n6   Got behind on updates. Boring part <rant> ...   Aug 14 2022, 02:25 PM
Chris914n6   I've gotten to the point where I have an engin...   Aug 14 2022, 03:07 PM
Chris914n6   Not much for today. Got the vq30 stripped except f...   Aug 16 2022, 12:17 AM
Mueller   Hi Chris, Just need to machine off the excess mat...   Aug 21 2022, 10:12 PM
Chris914n6   :D :Qarl: :headbanger: :beer2: Hi Chris, J...   Aug 22 2022, 08:45 PM
Chris914n6   Weekend update. A little WD40 overnight soak and ...   Aug 22 2022, 09:36 PM
Chris914n6   A rare moment of easier than expected. The 3.5 Fl...   Aug 24 2022, 10:40 AM
Chris914n6   Noting much to take pics of. Did some more cleanin...   Aug 30 2022, 04:46 PM
Chris914n6   Another series of small accomplishments. Used the...   Sep 1 2022, 05:37 PM
tygaboy   Chris - I'll get your parts shipped tomorrow. ...   Sep 1 2022, 06:02 PM
Chris914n6   Those look goooood! :drooley: Fun fact - y...   Sep 2 2022, 02:30 PM
tygaboy   Those look goooood! :drooley: Fun fact - ...   Sep 2 2022, 04:14 PM
Chris914n6   Another sleepy day of small projects. The Pathy T...   Sep 2 2022, 09:03 PM
Chris914n6   Well lookie here, I made #2 on Google :Qarl: h...   Sep 3 2022, 03:16 AM
Retroracer   Using Eggo waffle packets to make bracket patterns...   Sep 3 2022, 08:18 AM
Chris914n6   The acc cable bracket was a bit more involved desi...   Sep 5 2022, 02:31 AM
Mueller   These will ship out in the morning. Hope they work...   Sep 6 2022, 12:41 AM
Chris914n6   These will ship out in the morning. Hope they wor...   Sep 8 2022, 01:09 AM
Chris914n6   Today was Metal ---- in the mailbox :headbanger:...   Sep 14 2022, 01:34 AM
Chris914n6   :shitfan: :shoot2kill: Andrew Wang So the dude...   Sep 14 2022, 02:14 AM
Chris914n6   The cam adapters seemed to be the easy method, but...   Sep 14 2022, 03:16 AM
Mueller   Awesome amount of work and very ingenious Chris.   Sep 14 2022, 11:01 AM
Chris914n6   After RRC I wasn't in a hurry anymore... and I...   Dec 3 2022, 01:10 AM
Chris914n6   So it started as a simple MIA (Mosquito Involved A...   Apr 9 2023, 06:14 PM
Chris914n6   Three decisions were then made. One, I’d like to...   Apr 9 2023, 06:14 PM
Chris914n6   An hour here, an hour there, I narrowed down the s...   Apr 9 2023, 06:14 PM
Chris914n6   Continuing… That’s a lot of work to be done, ...   Apr 9 2023, 06:15 PM
FL000   Sounds like you are coming full circle and that’...   Apr 9 2023, 06:48 PM
ClayPerrine   I want to ask a curiosity question here. Why use ...   Apr 10 2023, 06:36 AM
Chris914n6   I want to ask a curiosity question here. Why use...   Apr 10 2023, 12:09 PM
ClayPerrine   I want to ask a curiosity question here. Why us...   Apr 10 2023, 12:39 PM
76-914   :blink:   Apr 10 2023, 08:49 AM
tygaboy   To @clayperrine Clay's question: Chris is ha...   Apr 10 2023, 09:09 AM
ClayPerrine   Plus, I suspect Chris is a charter member of the ...   Apr 10 2023, 09:26 AM
Chris914n6   To [b]@[url=http://www.914world.com/bbs2/index.p...   Apr 10 2023, 12:19 PM
rick 918-S   Just had to :bump: this.   Oct 25 2024, 05:48 PM
76-914   Yeah, c'mon Chris. We want to see that thing m...   Oct 28 2024, 08:14 AM
rick 918-S   Yeah, c'mon Chris. We want to see that thing ...   Nov 30 2024, 07:03 AM
Chris914n6   Alright Alright Alright :) Not much going on. ...   Nov 30 2024, 05:38 PM
mgp4591   Alright Alright Alright :) Not much going on....   Nov 30 2024, 11:56 PM
rick 918-S   Been there with the back issues. I just had a inje...   Nov 30 2024, 05:53 PM
- Lo-Fi Version Time is now: 28th October 2026 - 12:14 AM
