| mate914 |
Apr 10 2023, 07:04 PM
Matt ![]() ![]() ![]() Group: Members Posts: 936 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together?
thanks Matt |
| Retroracer |
Apr 11 2023, 08:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 655 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
What is done with bearing cover? Does 911 backing plate replace bearing cover or do we modify bearing backing plate and use both together? thanks Matt I made up spacer plates that both cover the bearing and set the 911 backing plate to the correct depth for the brake shoes to sit centered in the drum (for the handbrake function). I believe the required spacing is something like 5mm from memory? Chris Foley or Eric S would probably know the correct offset, - Tony |
mate914 911 emergency brake conversion question Apr 10 2023, 07:04 PM
mepstein One or the other. Not both. Apr 10 2023, 07:18 PM
mate914 Thanks Mark
Matt
Apr 10 2023, 07:33 PM
Luke M
What is done with bearing cover? Does 911 backing... Apr 11 2023, 02:27 PM
mate914 Can you show me the parts diagram of the outer bea... Apr 11 2023, 07:00 PM
mepstein Sorry. I meant you use the 911 parts. Not the 911 ... Apr 11 2023, 04:13 PM
mate914 I understood what you were saying.... I guessed th... Apr 11 2023, 07:02 PM
mate914 also have the tangerine kit.... Apr 11 2023, 07:03 PM
mate914 90133156100 is not available. alternatives?
Matt Apr 11 2023, 07:33 PM
Matt... Apr 11 2023, 10:00 PM
mate914 Got some coming.
Thanks, Matt Apr 12 2023, 04:50 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 11:31 AM |
