roundtwo |
Member ![]() ![]() Group: Members Posts: 325 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California ![]() ![]() |
OK, so I’ve scoured previous post about this topic and I’m now at this point.
-cleaning up some previous owner work - VDO fuel gauge part number V301030. Rated 0 to 90 ohms. - New stock sending unit putting out 36 ohms now as gas tank about 1/2 full. - all wires continuity tested and I’m sure i all hooked up correctly. Yes-grounds all checked. Problem- gauge reads full. -assumption the pin configuration on the sending unit plug is correct- see pic Fix? - install VDO gauge v301020. Range 10-73 ohms - Will this gauge work close enough with the stock sender? Or…. Do I need to replace the stock sending unit to match the gauge ohm range exactly? Thanks for the help ![]() ![]() |
roundtwo |
@914sixer
@datapace @root_werks @mmascari Hey folks It all worked out! Thanks for the help. Bought this one… https://vwparts.aircooled.net/VDO-Fuel-Gaug...6-p/v301020.htm VDO PN v301020 It’s pretty accurate from what I can tell- certainly more accurate than reading full all the time! One problem solved. |
Lo-Fi Version | Time is now: 12th July 2025 - 10:40 AM |
