Clutch pedal travel excessive |
peteinjp |
Apr 10 2023, 06:53 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not wanting to put any undue pressure on the TOB I pulled the cable end as far forward as i could while pushing the clutch lever as far back and adjusted the cable with no free play. Tube is good, cable, pressure plate, flywheel etc all have about 30,000kms. Pedal stop is low and yet I have to push the pedal all the way to the floor to keep from grinding in 1st and reverse. I can not pull the pedal back at all as described in the factory manual. It works but barely- the travel is too far even with the cable adjusted with slight pressure on the shift fork lever.
It seems to me there should always be just the slightest play in the cable- no?? Any thoughts? Pete |
jfort |
Apr 11 2023, 12:17 PM
Senior Member Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
I agree with the free play and the bushing. Mine with a bushing and adequate free play had 14mm of thread extending past the nuts
Lo-Fi Version | Time is now: 8th June 2024 - 02:54 AM |
