QUOTE(Mikey914 @ Apr 12 2023, 02:13 PM)
Shouldn't need to add in much if the flywheel hasn't been machined down too far. You will run out of throw before it disengages if it needs to be shimmed. However, DO make sure your transmission ground strap is fully grounded.
Flywheel is new- aase unit. All components have 30,000kms. The shift fork looks to be straight. I’ll check the ground strap for sure but the issue is the total throw.
QUOTE(technicalninja @ Apr 12 2023, 02:34 PM)
Might be a tight pilot bearing if it ONLY grinds gears when stopped.
I'd determine where the clutch is starting to grab when the pedal is released.
If it's just off the floor……..
It’s just off the floor with the cable adjusted and under tension.
QUOTE(rhodyguy @ Apr 13 2023, 03:12 AM)
A winter stuck in Tacoma? Outdoors? Uncovered? …… Did you rinse every section of the exterior? I would have.
This has caused numerous problems and ultimately will require the car to be dissasbeled. I pulled all the carpet and interior and rinsed everything inside and out with
Saltaway BTW I checked out the chimp sanctuary- very cool!
QUOTE(JamesM @ Apr 13 2023, 03:54 AM)
……..Doesn't matter how you adjust the cable, install spacers on it, or bend the clutch fork, the total range of motion of the clutch fork/throw out bearing is currently limited by its position in the housing.
Actually I have just a bit more room before hitting the housing- but not enough for long term as the disc wears.
QUOTE(930cabman @ Apr 13 2023, 10:39 AM)
It's possible the synchro's at 1 and reverse are shot
Transaxle was just rebuilt and shifts fine when I tighten the cable.
QUOTE(Dr Evil @ Apr 14 2023, 11:23 AM)
Not worth it for less than $5 in parts, and an afternoon of work.
Click in my sig for the free 31 paged of notes and look at the clutch adjustment section.
What I would give for an afternoon of free time these days…… that’s the real issue- haha. I have already downloaded your guide- great stuff. Thanks! I wonder if a m8 sealing washer might do the trick without the need for tape??? Might be a slick solution.
QUOTE(rgalla9146 @ Apr 14 2023, 09:33 PM)
First step....remove trans.
Yep- for me that means taking the car off the road for the foreseeable future. But once my 911 is back up and running later this year thats what I’ll be doing.
I did double check the roll pin and was really hoping that was the culprit- but its perfect.
Thanks all for the support. I have one temp fix idea to shorten the throw and will report back. I’ll get this worked out.
