QUOTE(Krieger @ May 12 2023, 11:23 PM)
Looks like you can file the washer where the clutch lever bottoms out. Maybe .060" there. Idk what that translates to in pedal travel, but it's easy to find out. I needed to do this on mine at some point.
Yeah I was eying that- but still good on clearance ATM.
QUOTE(914werke @ May 13 2023, 02:23 AM)
assume youve looked at this but thought its worth checking as I've seen this on multiple boxes where the stamped steel pivot fork is no longer ... true.
Mine is nice and flat. On that note I did consider spacing behind the nylon cup and also a small spacer under the retainer so it would not bend when tightened. For now I'm sticking with the tried and true- spacer under the ball pivot.
QUOTE(Dr Evil @ May 13 2023, 04:46 AM)
That sealing washer looks very thick. If it is too thick with that and the other washer, you run into the same problem as the level loses command at the angle you get with the spacers. Similar action to the failure that Rich posted above with the messed up fork retainer.
The actual sealing washer is the same thickness as a standard washer. the seal itself protrudes but when tightened it gets pushed into the threads of the bolt. I'll let you know in a month or so if it worked.
In total I used 3 washer....
The cable has very little free play which I think is what caused the wear not eh pressure plate fingers but the engagement as I mentioned is still low. I think I'll add my eccentric bully back to the mix to get a little more throw.
Click to view attachmentSo- went for a 4 hour long blast this morning and all is working ok. LOVE LOVE LOVE this car! So glad I went to the trouble to put it back together and who knows- if this fix works I can run it for a while longer if need be.
Thanks guys!
Pete
