Clutch pedal travel excessive |
peteinjp |
Apr 10 2023, 06:53 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not wanting to put any undue pressure on the TOB I pulled the cable end as far forward as i could while pushing the clutch lever as far back and adjusted the cable with no free play. Tube is good, cable, pressure plate, flywheel etc all have about 30,000kms. Pedal stop is low and yet I have to push the pedal all the way to the floor to keep from grinding in 1st and reverse. I can not pull the pedal back at all as described in the factory manual. It works but barely- the travel is too far even with the cable adjusted with slight pressure on the shift fork lever.
It seems to me there should always be just the slightest play in the cable- no?? Any thoughts? Pete |
Mikey914 |
Apr 11 2023, 11:13 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Shouldn't need to add in much if the flywheel hasn't been machined down too far. You will run out of throw before it disengages if it needs to be shimmed. However, DO make sure your transmission ground strap is fully grounded.
If not the cable will conduct the voltage and heat the wire. Stretching it slowly until you get exactly what you are showing. Eventually, if you keep adjusting it will snap. It could be an alternate problem, that is very easy to fix. |
Lo-Fi Version | Time is now: 7th June 2024 - 11:19 AM |
