> Overheating on the highway. 76, 2.0
SVG223
post Jun 5 2022, 10:59 PM
My 914 overheats on the highway. I had concerns about the air flap, but I think the thermostat has broken and it stays in the open position. I thought something might be clogging the fan but it looks clear. I wonder about the heater air hose that goes over the motor. It could be blocking some air possibly. I may try to tie it out of the way. After exiting the highway and stopping at a stopsign the idle was extremely low, I was surprised it was still running. I turned the engine off for a while and it ran better after it cooled down. Any ideas would be appreciated.
SVG223
post Apr 9 2023, 06:58 PM
I think the ignition timing has been retarded by a bunch. I just turned the distributor counter-clockwise enough to increase the idle by 1000rpm and it ran better, so far no overheating but it's not summer yet. I need to get a timing light. I tried to get it to ping but it didn't so I need the light. It is running well so far.
Superhawk996
post Apr 9 2023, 07:47 PM
QUOTE(SVG223 @ Apr 9 2023, 07:58 PM) *
You are playing with fire.
Detonation kills engines so fast you would hardly believe it. The ability to hear detonation on an an air cooled engine is impaired by the valve clatter and fan noise.
Get a timing light on it. Stop guessing
SVG223
post Apr 9 2023, 09:51 PM
QUOTE(Superhawk996 @ Apr 9 2023, 07:47 PM) *
Thanks, will do that. I didn't expect the timing to be off, purchasing it from a dealer that had done a tune-up on it. I had my doubts about it because of the vacuum hoses being misrouted. The engine runs much better now and doesn't overheat so far. That overheating was keeping me from driving it. I didn't know ignition timing had that much effect on engine temperature.
VaccaRabite
post Apr 10 2023, 09:44 AM
En Garde!
QUOTE(SVG223 @ Apr 9 2023, 11:51 PM) *
Too much or too little advance timing will raise temps.
Yes, put a light on it. Under no load it will be hard to make ping. It will certainly ping as soon as you put load on it once the engine is over-advanced.
Remove the crap from the engine that you are not using.
If you don't use the smog pump - pull it off the engine. Cap the ports. Those go directly into your combustion chambers. Don't trust duct tape! IIRC, an M8 nut cap works fine on the port.
And, yeah, get an inspection camera / borescope and look in your tins for debris especially your oil cooler. I'm sure its caked over with grime.
Zach
SVG223
post Apr 11 2023, 10:43 PM
QUOTE(VaccaRabite @ Apr 10 2023, 09:44 AM) *
Zach
I hear no pinging under load I may have guessed correctly, but the light will come in tomorrow so I can check. I pulled all of the smog crap off and getting some vacuum
caps tomorrow. I got a borescope camera and almost everything was covered with grease. I pumped a gallon of diesel fuel through the holes in the sheet metal, but I didn't get it all out.
VaccaRabite
post Apr 12 2023, 06:24 AM
En Garde!
QUOTE(SVG223 @ Apr 12 2023, 12:43 AM) *
Did you check and clean the oil cooler? Or is that what you were talking about?
Zach
SVG223   Overheating on the highway. 76, 2.0   Jun 5 2022, 10:59 PM
Superhawk996   Did it actually go into the red zone? If not then...   Jun 5 2022, 11:38 PM
SVG223   Did it actually go into the red zone? If not the...   Jun 6 2022, 12:17 AM
JamesM   This could be SO many things its hard to find a pl...   Jun 5 2022, 11:39 PM
Superhawk996   This could be SO many things its hard to find a p...   Jun 5 2022, 11:44 PM
SVG223   This could be SO many things its hard to find a p...   Jun 6 2022, 12:28 AM
JamesM   This could be SO many things its hard to find a ...   Jun 6 2022, 02:11 AM
SVG223   [quote name='JamesM' post='3006792' date='Jun 5 ...   Jun 6 2022, 12:40 PM
JamesM   There's a little wear on second gear synchro ...   Jun 6 2022, 09:06 PM
wonkipop   This could be SO many things its hard to find a p...   Jun 6 2022, 02:59 AM
JamesM   i got one of those them there grommets on my engi...   Jun 6 2022, 10:43 AM
wonkipop   i got one of those them there grommets on my eng...   Jun 6 2022, 04:39 PM
Superhawk996   Location? Ambient temperature? Speed driven, wha...   Jun 6 2022, 01:12 AM
SVG223   Location? Arkansas Ambient temperature? 80f Speed...   Jun 6 2022, 11:58 AM
JamesM   My gut (and my eyes with limited pictures) are tel...   Jun 6 2022, 02:25 AM
76-914   As James said that is the oil temp. Porsche actual...   Jun 6 2022, 08:07 AM
SVG223   As James said that is the oil temp. Porsche actua...   Jun 6 2022, 05:50 PM
emerygt350   The other symptoms point to something out of the o...   Jun 6 2022, 09:41 AM
Superhawk996   The other symptoms point to something out of the ...   Jun 6 2022, 09:48 AM
SVG223   The other symptoms point to something out of the ...   Jun 6 2022, 06:18 PM
Chaznaster   The other symptoms point to something out of the ...   Jun 6 2022, 06:56 PM
Superhawk996   Here's the weekly posting of oil temperature g...   Jun 6 2022, 09:41 AM
mgphoto   My 914 overheats on the highway. I had concerns a...   Jun 6 2022, 11:02 AM
SVG223   My 914 overheats on the highway. I had concerns ...   Jun 6 2022, 05:44 PM
wonkipop   [quote name='mgphoto' post='3006885' date='Jun 6 ...   Jun 6 2022, 07:08 PM
emerygt350   Good call. Never even thought about that.   Jun 6 2022, 11:12 AM
Superhawk996   Based on info above I'm more convinced that so...   Jun 6 2022, 12:17 PM
SVG223   Based on info above I'm more convinced that s...   Jun 6 2022, 10:59 PM
brant   Also wanted to ask which front spoiler or valance ...   Jun 6 2022, 01:49 PM
wonkipop   @SVG223 hey thats a good looking car you got hol...   Jun 6 2022, 04:31 PM
emerygt350   1- ODYR/SLX-11-1--BLUE-K - Cylinder Head Temperatu...   Jun 6 2022, 07:37 PM
FlacaProductions   1- ODYR/SLX-11-1--BLUE-K - Cylinder Head Temperat...   Jun 7 2022, 09:32 AM
Chaznaster   1- ODYR/SLX-11-1--BLUE-K - Cylinder Head Temperat...   Jun 8 2022, 05:40 PM
mgphoto   Remove the cat, there is an after market bypass pi...   Jun 6 2022, 10:52 PM
Lockwodo   Don't know if anyone else has mentioned this, ...   Jun 7 2022, 01:37 PM
emerygt350   That's a Porsche/diff type thing. Our fans ar...   Jun 7 2022, 03:11 PM
piscean914   i would start by confirming the oil temp in the su...   Jun 7 2022, 11:59 PM
rhodyguy   Delete/Replace the cat converter and clean the oil...   Jun 10 2022, 07:50 AM
SVG223   I think the ignition timing has been retarded by a...   Apr 9 2023, 06:58 PM
Superhawk996   tried to get it to ping but it didn't so I n...   Apr 9 2023, 07:47 PM
SVG223   tried to get it to ping but it didn't so I ...   Apr 9 2023, 09:51 PM
VaccaRabite   [quote name='Superhawk996' post='3070615' date='A...   Apr 10 2023, 09:44 AM
SVG223   [quote name='Superhawk996' post='3070615' date='...   Apr 11 2023, 10:43 PM
VaccaRabite   I hear no pinging under load I may have guessed ...   Apr 12 2023, 06:24 AM
SVG223   I hear no pinging under load I may have guessed...   Apr 12 2023, 07:27 AM
VaccaRabite   Just clearing out all the crap on top of the oil c...   Apr 12 2023, 11:30 AM
930cabman   Has a "high temperature" ever been confi...   Apr 13 2023, 06:37 AM
- Lo-Fi Version Time is now: 14th March 2026 - 10:50 AM
